Okay..one more time..a little help please. My 01 GT NA 3.8 has an issue where it periodically decides not to start. I just get a click and no crank. Sometimes will take a few turns of the key an it "catches" and cranks, and other times I have to turn the key upwards of 200 times to get it to start. Then it doesn't do it for 3 or 4 days, then does it again. It's like starter roulette... I've checked the batt, cables and grounds - removed the starter & had it tested, & cleaned all connections. The only modifications I have done to the ignition system is to remove the key interlock solenoid to stop the key from getting jammed in the ignition. Any Ideas?
Thanks in advance!
