Thread: Vacuum line...where does it go
Results 1 to 18 of 18
  1. #1 Vacuum line...where does it go
    Dec 2008
    Florida
    To make a long story short about the dealership replacing my LIM gaskets, and horrible gas mileage ever since, I will just say that I went out and discovered that one of my vacuum lines was going from the t valve to nowhere. I believe it is the supercharger bypass line? It is the middle one. Not the big one, or the hard one. The vacuum line runs around the back of the motor and next to the battery then it is unhooked from something, but what? I drive a 2000 Pontiac Grand Prix GTP.
    Thanks
    also, could that have been affecting my mileage and performance or making a coolant smell?
    I love my 5.0, but a little civilized muscle is a good thing! Especially when it always runs and doesn't leave you stranded on the highway.....
  2. #2 Re: Vacuum line...where does it go
    Dec 2008
    Florida
    to top it off, i just discovered while poking around it looks like its leaking worse now, all down the driver side towards the rear of the engine
  3. #3 Re: Vacuum line...where does it go
    Dec 2008
    Florida
    nobody knows this one? I looked at the vacuum diagram and it didnt help
  4. #4 Re: Vacuum line...where does it go
    Barksdale AFB, LA
    Quote Originally Posted by chrizzle17 View Post
    Pictures speak a thousand words. And you only waited a couple hours.
    2009 Subaru Impreza WRX STI
  5. #5 Re: Vacuum line...where does it go
    Dec 2008
    Florida
    Not trying to be impatient or anything, Im supposed to be leaving for a trip tomorrow morning and I was hoping I could fix the gas mileage problem before i go. I don't have a digital camera.
  6. #6 Re: Vacuum line...where does it go
    Barksdale AFB, LA
    Your description isn't very helpful. What is the "t valve"?
  7. #7 Re: Vacuum line...where does it go
    Dec 2008
    Florida
    The valve on top of the supercharger, at least I think Ive heard it called a valve after some searching. The one with the three hoses coming out of it, vacuum lines. The middle one or the hose on the long end of the T (the T is small too) is the skinny flexible one that wraps all the way around the engine bay and is one long piece ending somewhere around the battery area.
  8. #8 Re: Vacuum line...where does it go
    Dec 2008
    Florida
    Ive heard this vacuum line called the supercharger bypass
  9. #9 Re: Vacuum line...where does it go
    Barksdale AFB, LA
    That's not a valve, just a vacuum tree. The one in the center runs your HVAC blend doors. Supercharger bypass is the line coming off that closer to the front of the car.
  10. #10 Re: Vacuum line...where does it go
    Dec 2008
    Florida
    NYMCGP
    I found this It is the vacuum line he is talking about in this article
  11. #11 Re: Vacuum line...where does it go
    Barksdale AFB, LA
    Yep, that's your HVAC line. It provides vacuum so your HVAC doors can move.
  12. #12 Re: Vacuum line...where does it go
    Dec 2008
    Florida
    where do I plug it into and is that really the correct place for seafoam?
  13. #13 Re: Vacuum line...where does it go
    Dec 2008
    Florida
    Honestly if anyone can just tell me where this particular line plugs in, it would really help. Thank you
  14. #14 Re: Vacuum line...where does it go
    GXP Level Member ryangtp89's Avatar
    Maine
    Whats the vaccum line that goes to the tb or near the tb cause i broke that the other week and i just shoved the it back in the hose and it still isnt fully sealed and i think thats whats making my shifting going crazzy. Mine is a '99 gtp.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  15. #15 Re: Vacuum line...where does it go
    Dec 2008
    Florida
  16. #16 Re: Vacuum line...where does it go
    Barksdale AFB, LA
    I'd love to help but my Impala doesn't have vacuum operated HVAC. It's electronic, so I don't have that line to tell you where it goes. Going to need a GP member to actually go look.
  17. #17 Re: Vacuum line...where does it go
    Dec 2008
    Florida
    yea I appreciate it, guess Ill just wait until a GTP owner wanders by, or maybe ill find it if i keep looking
  18. #18 Re: Vacuum line...where does it go
    Barksdale AFB, LA
    It'll go back through the firewall into the passenger cabin at some point.
  1. Vacuum line for Fuel Press Regulator, where does it go?
    By 97grandprix38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2008, 12:17 AM
  2. car has vacuum in the dipstick
    By lilredss0287 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2008, 06:44 PM
  3. vacuum leak
    By boredout in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-15-2008, 08:22 AM
  4. Bad vacuum leak
    By boredout in forum General Tech Discussion
    Last Post: 07-14-2008, 02:21 AM
