Thread: Electrical for radio cutting out 98 GTP
Results 1 to 10 of 10
  1. #1 Electrical for radio cutting out 98 GTP
    Jul 2024
    New Mexico
    I was wondering if any of you have had an issue with electrical where when the ding goes off for opening door it cuts power to radio?
    I have gtp 98 I've looked online see one other person talk about it but never a solution to finding the problem other then checking grounds and they are all good...
    any opinions?
    also do they sell a new complete harness or is it just repairing an old one at this point?
  2. #2 Re: Electrical for radio cutting out 98 GTP
    St. Louis
    Are you referring to the chime signalling that a door is open?
  3. #3 Re: Electrical for radio cutting out 98 GTP
    Jul 2024
    New Mexico
    Quote Originally Posted by FordMan77 View Post
    yes
  4. #4 Re: Electrical for radio cutting out 98 GTP
    St. Louis
    Sounds like it could be a defective door switch in the latch maybe. The trunk open sensors are also known to be suspect, or just make sure your trunk lid is actually closed (it's happened, lol...)
  5. #5 Re: Electrical for radio cutting out 98 GTP
    Jul 2024
    New Mexico
    do you mean like it going off even when close? they work as intended its just when opening the door also trunk since you mentioned it the power cuts to radio (Completely Restarts the radio)they dont chime when running and everything is closed if that is what you mean
    or its really that sensor that causes that to cut power? that crazy but if so ill start there
  6. #6 Re: Electrical for radio cutting out 98 GTP
    Canada
    I do not recall but, if you are in the car with the doors closed, turn the headlights on, then remove the key, does the chime sound? If so, does this also cut the radio?
    '01 Grand Prix GTP Special Edition
    Trying to stay pretty close to stock now. Just a few bolt-ons for fun.
    Trying to keep it alive, pretty, and fun.
  7. #7 Re: Electrical for radio cutting out 98 GTP
    Jul 2024
    New Mexico
    Quote Originally Posted by jeepers View Post
    the chime when having door open with key set to accessories does cause the same issues
  8. #8 Re: Electrical for radio cutting out 98 GTP
    Jul 2024
    New Mexico
    i was told about even disconnecting that chime at the bcm... tho idk how to even figure out where that is in this diagram...
    is that a possible solution? if so how would i even do that? because the diagram is a complete Chinese to me
    Electrical for radio cutting out 98 GTP Attached Images
  9. #9 Re: Electrical for radio cutting out 98 GTP
    Jan 2014
    AR
    First thing I have done to these cars when bought is disconnect the chime. Follow the noise under the dash and you find a box with latches. Open it, unplug chime speaker. No more chime. Function of cutting radio power when door is opened with key off stays.
  10. #10 Re: Electrical for radio cutting out 98 GTP
    Canada
    It sounds like a problem with the wiring to the chime. As idrivejunk suggested, follow the sound to find the chime and check the wiring.
  1. Help with cutting out 98 GP
    By lgboogie19 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2013, 10:33 PM
  2. 4ch Amp Cutting In and Out
    By 2dee11 in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2013, 05:50 PM
  3. 3.8 n/a running hot and cutting off
    By GTPSHAWTY in forum General Tech Discussion
    Last Post: 12-05-2011, 12:52 PM
  4. radio cutting out
    By gtcoup in forum Off Topic Discussion
    Last Post: 12-26-2010, 01:25 AM
  5. Car Cutting out
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-31-2008, 04:48 PM
