Thread: Subframe mount change?
Results 1 to 6 of 6
  1. #1 Subframe mount change?
    Jul 2024
    New Mexico
    i have been having an issue lately when stepping on gas or braking i am hearing a clunking noise under passenger side around feet area, i changed the engine mount(was bad.. leaked everywhere)/dogbones/and trans mount but the noise still is continuing.
    i got under there and seen the subframe mounts in that area
    here is the driver side and passenger side of the mounts on subframe the passenger side has all that hydraulic fluid from old Engine mount
    Driver Side Imgur links Passenger Side
    im assuming these are to be changed for that "Clunk noise" what is best options to get this done if this is the case? take subframe off completely? i tried getting it off with it up and it wasnt come out easy on passenger side
  2. #2 Re: Subframe mount change?
    St. Louis
    Before jumping into subframe mounts, have you looked at the lower control arms? These are known to "clunk" when the bushings get worn. Easy change since you can buy the entire arm with ball joint installed.
    If it is indeed a subframe mount, you should be able to drop the rear of the cradle and sneak them out. Search the forum here and see what you can find. If you can't find anything on it let us know. Sometimes the search sucks, lol.
  3. #3 Re: Subframe mount change?
    Jul 2024
    New Mexico
    Quote Originally Posted by FordMan77 View Post
    i changed both aswell when i did my CV Axles that was before the Engine mount
    i will look to see what i can find in the search
    i havent been able to find anything on here about the subframe
  4. #4 Re: Subframe mount change?
    Canada
    '01 Grand Prix GTP Special Edition
    Trying to stay pretty close to stock now. Just a few bolt-ons for fun.
    Trying to keep it alive, pretty, and fun.
  5. #5 Re: Subframe mount change?
    Jul 2024
    New Mexico
  6. #6 Re: Subframe mount change?
    Canada
    Let us know how you make out. Drop some before and afters.
  1. How to change lower motor mount and trans mount
    By AlanP in forum How To Write-Ups/Tech Tips
    Last Post: 01-10-2021, 12:39 AM
  2. Front subframe mount?
    By 310toumad in forum Brakes/Suspension/Chassis
    Last Post: 06-13-2016, 01:07 PM
  3. subframe mount interchange
    By 91parkave in forum General Grand Prix Discussion
    Last Post: 04-26-2015, 08:19 PM
  4. '98 3.1L lower motor mount, tranny mount replacement help
    By Patrick551 in forum General Tech Discussion
    Last Post: 10-07-2012, 11:37 PM
  5. L67 coil mount/engine mount bracket (passenger side) on an L36
    By BlownBigBlock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2012, 10:08 AM
