Thread: AC not taking refrigerant
Results 1 to 4 of 4
  1. #1 AC not taking refrigerant
    Jun 2018
    Lehigh Valley
    The AC is not blowing cold air and the compressor isn't kicking on due to the low refrigerant. It is definitely low and when I put on one of those charge bottles nothing goes into the system. There is a pressure sound when I remove the bottle so there is some pressure in the system. What would prevent it from charging?
    '97 Grand Prix GT Coupe
    '05 Grand Prix GTP Sport Red Metalic SOLD
    '05 Grand Prix GTP Silver
  2. #2 Re: AC not taking refrigerant
    Jun 2018
    Lehigh Valley
    Sorry, I forgot to say this is on the '97 GP.
  3. #3 Re: AC not taking refrigerant
    HUDSON
    At the very least you need a set of gauges to monitor low and high pressure side of the system, however it wont tell you if the proper amount of ref. is in the system, for that
    you need to vacuum down the system and install the proper charge in lbs., check the sticker in the engine compartment for the proper weight in refrigerant the system holds,
    my 2000 GTP holds lbs.
    If there is some charge in the system but unknown amount, it will need to be recovered so the proper amount can be installed.
  4. #4 Re: AC not taking refrigerant
    GT Level Member mguzzo's Avatar
    Buffalo NY
    if the system is low / no refrigerant you may have to jumper the compressor to force it to turn on, then it will start taking refrigerant.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  1. Which refrigerant?
    By GYSOT1 in forum General Grand Prix Discussion
    Last Post: 09-05-2021, 06:25 PM
  2. What plugs into this A/C Refrigerant Hose?
    By ahl395 in forum General Tech Discussion
    Last Post: 03-15-2012, 11:37 PM
  3. A/C Refrigerant Recharge
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-10-2011, 12:59 PM
  4. Taking out the cat
    By Jakescoots in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2010, 10:26 AM
  5. A/C refrigerant leak
    By m0ng00se in forum General Tech Discussion
    Last Post: 04-15-2010, 10:15 PM
