Thread: 72 gp sj no spark
Results 1 to 8 of 8
  1. #1 72 gp sj no spark
    Feb 2009
    Alabama
    72 GP SJ with no spark...
    Can't I just run 12+ from battery to + side of coil to see if problem is between key and coil or coil and plugs?
    I just got this car from my neighbor... it had been in his basement since 1984 he was original owner. I have always had fords but I couldnt turn down a 72 GP SJ with no rust all original 455 12 bolt rear even had build sheet tucked away in door panel. oh yea $1500 got it.
    It has standard coil with standard points dist.
    I have changed oil, tranny fluid, plugs, wires, points & cond, and coil
    I got no spark, had no spark before changin coil and points.
    How do ya test a coil can ya take wire out of dist and hold close to ground and see a spark?
    Any help or sugestions would be greatly apreciated.
  2. #2 Re: 72 gp sj no spark
    Apr 2008
    Chillin at the Beach , VA
    Welcome to the forums. Happy to have you here. Would tell you to post up in the correct section, but don't believe we have one for the older GP's. Nice find and purchase by the way. would love to see some pics of it. Does your coil have a good ground? It's hard for me to really say on anything else without being there to trouble shoot. Good lick with her though.
  3. #3 Re: 72 gp sj no spark
    GXP Level Member ryangtp89's Avatar
    Maine
    welcome to the forum!!
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  4. #4 Re: 72 gp sj no spark
    Feb 2008
    Welcome!!! Oh yeah, this is the INTRO section!!
  5. #5 Re: 72 gp sj no spark
    I live here. UR LOSN's Avatar
    Rockford, IL
    yes you should be able to connect them. one to your ignition switch, so when the key is on.. you will have power to the coil. but you could connect them directly if you wanted... but you would have ahard time turning the car off.... without an interupt.
    Welcome to the forums!! post some pics when you get a chance!
  6. #6 Re: 72 gp sj no spark
    Oklahoma
    Welcome to the community.
    Moved this to the correct area.
  7. #7 Re: 72 gp sj no spark
    Feb 2009
    Alabama
    I figured it out... old points coroded new points not opening
    once I set the points to .019 and they actualy opened and closed I got my 12v to the coil
  8. #8 Re: 72 gp sj no spark
    Apr 2008
    Sweet. Still like to see some pics of that baby. How does she run?
  1. What spark plugs?
    By Dwhip in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-25-2009, 08:21 PM
  2. spark plugs
    By NEONNIGHT34609 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-07-2008, 09:43 PM
  3. Spark
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2008, 04:06 PM
  4. Spark Plugs
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2008, 10:45 PM
  5. no spark
    By faboskay57 in forum General Tech Discussion
    Last Post: 07-10-2008, 07:41 AM
