Thread: "Check Left Tire Pressure"
Results 1 to 4 of 4
  1. #1 "Check Left Tire Pressure"
    Aug 2021
    Calgary
    Hi All...New to the forum and new to the GP world. I have a 2007 GP that has an irritating issue. I keep getting a "Check Left Tire Pressure" on my message center.
    I am trying to reset the TPMS system as all 4 tires are inflated to the proper pressure and are not leaking. I tried following the one way where the ignition is switched to on without starting and then pressing the lock/unlock buttons on the keyfob simultaneously and I hear the horn chirp twice. I inflate the front left tire beyond the normal PSI and I hear another double chirp...I go to the front right and tried deflating the tire pressure as well as inflating it to hear another chirp, but hear nothing to continue to the rear right tire. What am I doing wrong? All I want to do is to make that warning light on the dash and instrument cluster go away... a reset.
    Any help will be greatly appreciated. I do not have a TPMS reset tool and don't want to take it to the dealership.
    Cheers....
    Britt
  2. #2 Re: "Check Left Tire Pressure"
    SE Level Member Xerosiv's Avatar
    Jun 2020
    Justin, Texas
    Probably the sensor itself, they have a built in battery that goes bad after a while. Any tire shop should be able to switch it out for you.
  3. #3 Re: "Check Left Tire Pressure"
    Sep 2014
    Worcester, MA
    Quote Originally Posted by 07GPinCanada View Post
    [snip]
    Cheers....
    Britt
    Here is one of my favorite YouTubers going through a reset procedure without a tool. Of course this assumes that none of the batteries are dead, however if they haven't been replaced before it's probably time! ("Industry standard" battery life is 5-10 years, although I seldom see one die before 10 years old)
    -Bob C.
  4. #4 Re: "Check Left Tire Pressure"
    Sep 2014
    Worcester, MA
  1. Still getting "Check Security System" and got "Battery Saver Mode"
    By J57ltr in forum General Tech Discussion
    Last Post: 08-08-2015, 01:36 AM
  2. Correct tire pressure for 20"s?
    By Juanmiguel in forum Tires & Wheels
    Last Post: 06-21-2012, 12:16 PM
  3. 97 Grand Prix GT "check tire pressure" light on
    By fju2 in forum General Tech Discussion
    Last Post: 08-04-2011, 07:37 PM
  4. "half" light tinting expiriment. looks cool. check it out.
    By colindunn in forum Visual/Body Modifications
    Last Post: 06-30-2010, 08:18 AM
  5. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
