The owner's manual is, of course, unenlightening on this subject.
What light bulbs go in the steering wheel audio controls? And are they plug and play, or is this one of those cases where you have to solder?
#2
Re: Steering Wheel Lights
11-26-2020
not plug and play. theres how to's here on bulb replacement on switches.
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
#3
Not anywhere I can find. One thread features a link from SaukRapids that no longer works. Everyone else on the thread says there ought to be a writeup, but there isn't. Which, unless your search skills are better than mine, is where we're still at, three years later.
#4
11-26-2020
theres stuff on yt. if changing em to led you need tp add a resistor. if going stock, just unsolder and resolder in the new bulbs, or the easy way out is to just buy new switches.
#5
11-27-2020
Your best bet would be to get new control pods and replace them. We all know you can't understand things written in English, why bother trying to educate you.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#6
Say hi to the mods for me....
#7
replacing them is not a standard repair, the switches were designed to be replaced as a unit. they pop out and then you can disassemble and solder new bulbs in them.
"Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
Post Thanks / Like - 1 Thanks, 0 Likes, 0 Dislikes
LouF thanked for this post
