Thread: Random stalling
Results 1 to 16 of 16
  1. #1 Random stalling
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I am having issues with my 07 supercharged stalling while trying to pull out of a driveway at a higher speed. Sometimes it also does it accelerating around a corner really fast. The car usually will start back up when put in neutral and I can continue on. I do not see anything in scans that would indicate this issue. I have gotten it to do it on scans a few times but really don’t know what to scan for. Looks like the Maf is reading fine. From what I can tell there is no power steering pressure sensor for this to happen. It’s hard to diagnose since it is for the most part a random issue. Any suggestions??
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #2 Re: Random stalling
    May 2008
    Schuyler, NE
    Any check engine lights?
  3. #3 Re: Random stalling
    GT Level Member mguzzo's Avatar
    Buffalo NY
    ive had issue with random stalling. I swapped the MAF even though scans were good and no codes, and it hasn't come back.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  4. #4 Re: Random stalling
    GTP Level Member
    Jun 2016
    Cleveland ohio
    No check engine light GTP.
    I was thinking the MAF as well mguzzo. It is only about a year old but that means nothing.
  5. #5 Re: Random stalling
    May 2008
    Schuyler, NE
    What brand of maf is it? If it's not Hitachi/Delphi/ac delco, they don't have the greatest track record.
  6. #6 Re: Random stalling
    GTP Level Member
    Jun 2016
    Cleveland ohio
    It is a Delphi. What brand do you recommend?
    Another issue is this damn Pacesetter collector. It will not stop leaking. None of the muffler shops will touch it. I should eliminate them but it costs way too much. ZZP headers are over 1k so that’s not an option. I don’t have the stock Ported manifold setup anymore. eBay headers are garbage from what I’ve read.
    Local muffler shops wont touch my headers. A local Performance/ fabrication shop BDK Performance could probably fabricate something but will probably cost a ton. PITA!!!!
  7. #7 Re: Random stalling
    pull the fuse box in the engine bay and look for the hi-speed fuel pump and bend tab 85 and see if it helps in the stalling when turning
    clic this link and go to post #8---> Fuel Pump Resistor
  8. #8 Re: Random stalling
    GTP Level Member
    Jun 2016
    Cleveland ohio
    FST- does this work with the 04 up Grand Prix?
  9. #9 Re: Random stalling
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Dumb question. How do I know which way the relay goes? Does the 8866 face forwards the left or right? I searched and can not find this information!
  10. #10 Re: Random stalling
    May 2020
    Pittsburgh
    Try the Crank Position Sensor.
    I had a very similar issue a while back, car would stall every day on the way to work. Right at the same place on the highway too.
    It could be difficult to test, but it's relatively simple to replace.
  11. #11 Re: Random stalling
    GTP Level Member
    Jun 2016
    Cleveland ohio
    The bend the tab thing doesn’t work on my 07. Won’t start
  12. #12 Re: Random stalling
    Nov 2014
    Macon, GA
    try cps
  13. #13 Re: Random stalling
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I just tried the Crank relearn yesterday. We shall see. Thanks
  14. #14 Re: Random stalling
    May 2020
    Pittsburgh
    Not a relearn... the actual sensor.
  15. #15 Re: Random stalling
    May 2008
    Schuyler, NE
    Yeah, random dying without a code is a lot of times the crank position sensor.
  16. #16 Re: Random stalling
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Update: I tried the relearn and it worked. The crank sensor is probably going bad.
  17. Likes Scottydoggs liked this post
  1. Random Stalling only when hot
    By cornflake in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-01-2015, 06:50 PM
  2. Random stalling
    By Jim1658 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2014, 01:45 PM
  3. Random Stalling PLEASE HELP IF YOU CAN!!
    By Bre in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-08-2012, 04:01 PM
  4. Random Stalling
    By 02Grandgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-25-2010, 01:17 AM
  5. random stalling
    By krippled in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2008, 08:28 PM
