Thread: lesabre clunking when braking
Results 1 to 5 of 5
  1. #1 lesabre clunking when braking
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Hi folks,
    Posted this hear because not wbody. m
    I visited my mom in TN over the weekend, drove her 2000 lesabre for the fist time. Strong 3.8, rides nice AC works etc .
    One major issue, you press the brakes and it clunks. Does not clunk when shifting into gear, or from forward to reverse. I dont think its motor mounts, none of the classic symptoms. I was wondering if anyone had some idea as to what it was. I tried pretty hard to recreate the issue without pressing the brakes and couldnt.
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: lesabre clunking when braking
    St. Louis
    Check the front control arm bushings on both sides, especially the ones facing the frontend. Check all the motor mounts especially the front one near the fan. Likely it's a control arm.
  3. #3 Re: lesabre clunking when braking
    Dec 2008
    Lawndale, CA
    Mine did the same thing for a long time. It would do it when coming to a slow stop or on uneven surfaces. Turned out it was the control arms. Replaced them and all that went away.
  4. #4 Re: lesabre clunking when braking
    Nov 2019
    WI
    Former LeSabre owner here. I agree with the other posts. Most likely the front lower bushing is worn on the lower control arm. Mine was the right side. Moog makes a replacement arm with a heavier duty bushing installed.
  5. #5 Re: lesabre clunking when braking
    Prior Bonne guy here (aka dressed up LeSabre) and all the above are good, check the caliper/bracket bolts as well. A loose one will do that was well. Check sway bushings too.
  1. P0133 97 Buick Lesabre
    By Impala131 in forum General Tech Discussion
    Last Post: 03-30-2016, 02:39 AM
  2. 4T65E from LeSabre into GP
    By kc199 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-29-2011, 10:20 AM
  3. 92 buick Lesabre
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 11-02-2009, 05:15 PM
  4. Odd issue... Pop/Clunking sound shifting into 2nd OR braking hard...
    By Iron Indian in forum General Tech Discussion
    Last Post: 07-09-2009, 10:28 PM
