Thread: Torque Spec
Results 1 to 5 of 5
  1. #1 Torque Spec
    May 2012
    Canada , Sarnia
    This weekend im going to be working on my 06 grand prix gxp and replacing the following the parts just need the correct torque specs and I'm going to be cleaning my throttle body can I move the flap or no ??
    - Axle Nut
    - Tie Rod Castle Nut
    - Ball Joint Castle Nut
  2. #2 Re: Torque Spec
    May 2012
    Canada , Sarnia
    Replacing
    - Front Wheel Hubs
    - Tie Rod Ends
    - Ball Joints
  3. #3 Re: Torque Spec
    Apr 2015
    Columbus, OH
    Axle nut....4 grunts.
    Castle nuts....1 grunt.
    Top Swapped 01 Imp
  4. #4 Re: Torque Spec
    There are correct specs for everything.
    reality though I air gun on axle nuts without issues. Real torque is probably around 130-150 ft lbs
    Tie rod end probably 20-40 ft lbs and then a touch further until you can line up for the cotter pin (again..I use air gun)
    Ball joint torque isn't happening unless axle is out and to do that you'd have to pull the strut bolts and compromise alignment. Using a wrench I go til it stops, then give it an extra heave ho if needed to line up the cotter pin.
  5. #5 Re: Torque Spec
    The axle nut should be 118 ft lbs if I remember correctly.
  1. Bolt size and torque spec thread.
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-18-2016, 07:12 AM
  2. Subframe bolts torque spec
    By TDgrand in forum Brakes/Suspension/Chassis
    Last Post: 11-01-2013, 10:34 AM
  3. inner tie rod torque spec
    By jhnnyboz in forum General Tech Discussion
    Last Post: 08-08-2011, 09:01 PM
  4. trans pan torque spec
    By 91gpse in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 11-26-2010, 10:28 PM
  5. torque Spec's for front exhaust manifold?
    By luckyjack04GTP in forum General Tech Discussion
    Last Post: 05-30-2009, 12:29 PM
