Thread: ODBII Scanners and Apps
Results 1 to 5 of 5
  1. #1 ODBII Scanners and Apps
    Jun 2016
    n/a
    Hello everyone. I hope there are still some active folks on this forum!
    I did a couple simple searches and didn’t see any recent posts about this so I’d like to ask for input.
    I’m in the market for an ODBII Scanner and/or App and looking for suggestions.
    What do you all use and recommend?
    Do you like wired (all in one) solutions, or wireless/Bluetooth devices to pair with an app?
    Do all scanners read for KR in the GTPs or are there specific parameters I need to look for?
    If you use a BAFX, what apps do you recommend?
    The best couple options I am considering are:
    Blue Driver and their own app:
    Robot Check
    BAFX:
    Robot Check
    or
    Robot Check
    Foxwell wired/all-in-one: Robot Check
    One more random (noob) question: Are there ODBII Scanners that can also be used to tune and adjust settings or is it better to use a separate device for that?
    I would like to use it to read and clear codes, read KR, and view live information while test driving (if possible)
    I’ve got a 98 GTP but also want the tool to read as many vehicles as possible. I have mostly Windows and Apple iDevices at home, but do have an android based Kindle available also.
    Thank you all in advance!
  2. #2 Re: ODBII Scanners and Apps
    SE Level Member ThatOldCarSmell's Avatar
    Apr 2020
    Upstate SC
    I recently purchased the obdlink LX OBDII adapter, and have been using it with the android app Torque. It can read KR, and GM- specific parameters once enabled. Torque works with a lot of BT adapters, and there is a list of the "best" ones if you find that app in the play store and navigate to their website. as far as wired options, I'm sure there are plenty, and I'd imagine a lot of them are more reliable than the BT route, but I guess it's a matter of how much you want to spend v/s what you want it to do. I would love to have just sprung for HP Tuners off the tip, as that monitors/ logs pretty much everything everything, and you can tune with it also, but that costs more than I want to spend at the moment.
    99 GTP:
    ZZP FWI , ZZP 3" catted DP, Resonator delete,The occasional Poly bushing, ZZP front sway Bar, NGK TR6's, LED Headlights, 180* TStat, Anti- pogo washers ...This list seemed a lot longer before I started typing....
  3. #3 Re: ODBII Scanners and Apps
    torque app is great. but i also use this app for reading abs codes. its free too it even clears history of abs codes. ChevroSys Scan Free - Apps on Google Play
  4. #4 Re: ODBII Scanners and Apps
    Apr 2020
    Upstate SC
    Does Torque not read ABS codes? I have not had the light come on, so I've had no reason to check ABS yet.
    99 GTP:
  5. #5 Re: ODBII Scanners and Apps
    Quote Originally Posted by ThatOldCarSmell View Post
    it only does p codes. that app i posted does everything even air bag codes. and live data. but ive not tried the live data part. i got it mainly for abs stuff.
  6. Likes ThatOldCarSmell liked this post
  1. What scanners can delete rear o2 code?
    By MrDniceL36 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-23-2014, 10:26 PM
  2. Police Scanners
    By Thunderturd in forum Off Topic Discussion
    Last Post: 07-14-2010, 11:37 PM
  3. Advance sale on OBD II scanners
    By Madness in forum General Tech Discussion
    Last Post: 05-20-2010, 09:35 PM
  4. Facebook Apps
    By Deimos in forum Off Topic Discussion
    Last Post: 01-03-2010, 10:18 PM
  5. scanners ??????
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2008, 02:49 PM
