Thread: Who;s good with Electrical?
Results 1 to 5 of 5
  1. #1 Who;s good with Electrical?
    Jul 2016
    St. Louis
    My highbeams seem to stay on all the time when the fog lights are on. If I turn the fog light switch off, the highbeams will go off. The Multifunction switch has been replaced with no change. Any ideas on where to look next or what the cause is?
  2. #2 Re: Who;s good with Electrical?
    SE Level Member ThatOldCarSmell's Avatar
    Apr 2020
    Upstate SC
    Quote Originally Posted by waupachino View Post
    Curious, if the fog light switch is off, do the high beams still work as they should?
    And to answer your question, it sounds to me like some insulation has gotten nicked or melted where the hot for highs and fogs run close together, so that could literally be anywhere from the mfs forward until they split back off near the radiator support. Time to bust out a multi-meter.
  3. #3 Re: Who;s good with Electrical?
    Jul 2016
    St. Louis
    Yes, the highbeams work as they should with the fog light switch off.
  4. #4 Re: Who;s good with Electrical?
    May 2020
    Pittsburgh
    Sounds like you're looking for a short to power (to the fog light power/fuse/relay) in the high beam circuit.
    I'd check behind the light switch first, then move to the harness behind the headlights, then to the fuse/relay box.
  5. #5 Re: Who;s good with Electrical?
    I'd also check the ground behind the driverside headlight. A bad ground could let the power go through it to light up other stuff.
  1. Key Stuck, Car Dead, and...Battery Good, Alternater good
    By izzy in forum Introductions/Noob Questions
    Last Post: 01-14-2014, 11:13 PM
  2. HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    By chamilton89 in forum Audio, Security & Visual Electronics
    Last Post: 08-06-2012, 09:10 PM
  3. Would this look good, really good, okish, bad, or really bad?
    By Jakescoots in forum Visual/Body Modifications
    Last Post: 02-02-2011, 06:21 PM
  4. Need some electrical help
    By Green97GTP in forum General Tech Discussion
    Last Post: 08-17-2010, 07:28 PM
  5. Electrical
    By 97gp97 in forum General Tech Discussion
    Last Post: 11-10-2008, 04:02 PM
