Thread: FYI: Coolant bleeder alternative, Dorman 13960 (brake bleeder)
Results 1 to 2 of 2
  1. #1 FYI: Coolant bleeder alternative, Dorman 13960 (brake bleeder)
    Mar 2015
    Connecticut
    For reference, my car is an '01 Pontiac Grand Prix GTP. I assume many others use the same coolant outlet and bleeder.
    The coolant outlet to the upper radiator hose (thermostat housing) has a bleeder screw for getting air out of the coolant system. The head of the inner screw is broken on mine, so I can't bleed it (which I'll need to do as I'm about to replace leaking heater hose coolant elbows.)
    I found an alternative. Dorman part 13960, which is actually a brake bleeder screw.
    Dorman Products
    The original part had a bleeder hole on the side. The Dorman brake bleeder bleeds through a hose fitting. Actually might work better than the original, if you attach the fitting with a hose to a small reservoir of coolant. Squeeze the hose to let air out, release to suck coolant back from the small reservoir, even with engine off and thermostat closed. Probably want to put a vacuum cap on the hose fitting to keep out dust and grime.
  2. #2 Re: FYI: Coolant bleeder alternative, Dorman 13960 (brake bleeder)
    Mar 2015
    Connecticut
    I think the original part is ACDELCO 10070107, but I found the Dorman part browsing store shelves.
  1. coolant air bleeder leak for years
    By hitnf in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2015, 04:14 PM
  2. No coolant from bleeder?
    By Ultra440 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2012, 11:13 PM
  3. Brake Line Bleeder size?
    By PlayingMechanic in forum General Tech Discussion
    Last Post: 03-01-2012, 01:07 AM
  4. Dorman Coolant Elbows... Two Blowouts in 8 Days...
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2012, 09:27 AM
  5. Need help with broken Bleeder screw when replacing thermostat!!!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 02-15-2012, 09:16 AM
