Thread: Seat covers availability - OEM or aftermarket, 2001 GTP?
Results 1 to 20 of 22
  1. #1 Seat covers availability - OEM or aftermarket, 2001 GTP?
    Nov 2016
    N. California
    My son and I have maintained his old 2001 GTP in order to keep it alive for his college years, so easily another 4 years as this is his first semester. While the car is very good mechanically thanks to the venerable 3.8L Buick and rebuild/replacement of anything that needs attention, the driver's seat is an absolute wreck after nearly 20 years and 180K miles.
    I would be willing to hire a good upholstery mechanic I know to rebuild the seat, but this is a far more practical exercise if the original seat covers can be sourced. Or even a decent aftermarket fit. It starts to get pretty expensive if they have to be hand-sewn from purchased leather swaths. The seats are black leather, BTW.
    Is a cost effective, decent-quality set of seat covers (upper and lower) available? It was a common care, maybe there is aftermarket support?
    Lifespeed
    2001 GTP
  2. #2 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    GT Level Member Supercharged99's Avatar
    Apr 2011
    Kansas City, Mo
    you might look on carid.com and look for covers specific to the vehicle. I got some for a different vehicle a couple years back and they fit like a glove. MUCH better than the universal fit garbage you normally find. I believe they were like $200 for both front seats and they have a lot of different styles and fabrics to choose from. Just make sure you get vehicle specific.
    1999 GTP...stock for now
    2007 Suburban...far from stock
    1991 GMC Dually...74k original miles. Work in progress. Far from done.
    1977 C-10 (my baby)...too many mods to list
  3. #3 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    Nov 2016
    N. California
    Quote Originally Posted by 05GPBase View Post
    A cover won't do anything for the disintegrated foam. I'm afraid at this point the only real fix is a seat rebuild, painful as it is for a worthless old car. And at $200, it may be possible to do it for not a while lot more, I'm guessing maybe $400 if my son pulls the seat out himself and delivers it to the shop. No leather at that price either . . .
    Lifespeed
    2001 GTP
  4. Likes Supercharged99 liked this post
  5. #4 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    Apr 2011
    Kansas City, Mo
    Quote Originally Posted by Lifespeed View Post
    Agreed. I didn't know your foam was that far gone. Have you look at theseatshop.com? Not sure if they have anything for a Grand Prix but they might and would be worth a shot to take a look.
  6. #5 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    Never Never Land
    Getting newer seats from an 04-08 is also an option and junkyards sell seats pretty cheap. Front's are a direct bolt in and some minor wiring will get the power and heat working if you go that route. Rears are easy too if you wanted to do those.
  7. #6 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    St. Louis
    I vote 04+ swap. Way more comfortable and will be in better shape. Maybe even the GXP seats if you want to go all out as they came in black so it won't be noticeable. The stock 97-03 seats aren't worth the $$ to try and redo since they sucked when new. I swapped full 06 GXP leather/suede seats in my 00 GT and they're great, and I have a heated drivers seat to boot!
  8. #7 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    Oct 2014
    portland oregon
    3rd vote on the 04+ seats. I just did mine and I love them.. you sit alil higher in the car.
    If your son is 6'4" it may be a issue. As stated by other posters they are way more comfortable.
    If your on a budget and cant find leather the cloth ones are pretty nice to but not heated
    I waited 4 years to find a primo set of seats.. Best comes to those who wait
    If you do opt to replace the seats the carpet isnt much more of a stretch to take out.. well worth cleaning. Taking 22 years of crap out of my carpet has left my car smelling nice and fresh
    Sent from my SM-N920V using Tapatalk
  9. #8 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    St. Louis
    +1 on the carpet cleaning. All you need to do is pull the center console, scuff trim/belt covers and you're there.
    I pulled the stock carpet out of my 00 GT and cleaned it until the water coming from it didn't look like Coca-Cola. Let it bake in the sun to be sure the backing was dry and reinstalled. Looks brand new and have never had a foul smell from it. Used a lot of Folex on it to clean it out w/o damaging the dye in it. Turns out I really do have graphite carpet, lol.
    FWIW, I'm 6' 2" and don't have too much issue with the GXP seats. It's tighter on the headroom but not impossible to live with.
  10. #9 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    Nov 2016
    N. California
    Thanks for the tips. How incompatible is the wiring? He has heaters and power.
  11. #10 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    Nov 2016
    N. California
    Quote Originally Posted by FordMan77 View Post
    Please describe what wiring modifications are required in the donor is '06 power and the recipient is '01 power. Are the connectors different, must splice both ends of the donor connector, etc?
    Lifespeed
    2001 GTP
  12. #11 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    Oct 2014
    portland oregon
    Seat Swap: 04+ to 97-03[*]
    Post #21 has the wire swap.
    Also is the passenger heat wiring is in there somewhere if you want to go all in
  13. Likes Supercharged99 liked this post
  14. #12 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    Dec 2019
    Omaha, NE
    The thread that wowitsfast linked to was a huge help to me as far as the seat swap. I pulled mine out of an '05, but I believe everything in the '04-08 seats is the same. The driver's side is a fairly easy splice into the existing wiring, there are just a few wires from the new seat that aren't used. The passenger side is a bit more involved, I got another switch out of another junkyard 6th gen and cut the harness for the switch off of the center console harness. I don't remember the colors of all the wires on the heated seat switch harness, but I do know that the pink and blue wires run to the seat, so I spliced the other wires on the harness into the same-color wires on the existing harness for the driver side and ran the blue and pink wires under the carpet to the passenger seat. This thread has a pretty good description of how the passenger seat should be wired, although they used a different harness (if you can find a junkyard car to pull the factory switch/harness from I highly recommend it), the seat wiring is the same. For the power/ground for the seat itself, I ran the hot wire to an add-a-circuit so both seats are working off of the factory driver's side seat circuit, and spliced the ground into a different ground. Probably wasn't the most professional wiring job ever done, but hey, it works! All in all it was a pretty straightforward swap, and the newer seats, switches, and harnesses were just over $100 total and are MUCH nicer than the stock seats.
  15. #13 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    Nov 2016
    N. California
    LOL, I wish I got the seats for $100. The passenger wiring is only for the heater I think, it's a manual seat. I may skip wiring the heater, just wiring the airbag switch.
  16. #14 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    Dec 2019
    Omaha, NE
    Gotta love U-Pull-It!
    I think they all had manual passenger seats, which does make wiring a lot simpler at least. I didn't do anything with the airbag switches in the seats, I haven't found anything on what to do with that wiring. I also didn't realize that the seat-side buckles aren't compatible with the belt-side buckles, so I had to swap out the seat buckles from the old seats.
    '99 Grand Prix GT - The winter beater - top swap coming this summer
    '00 Honda S2000 - Turbonetics T3/T4, E85 tune, too many other mods to list
    '14 BMW 528i - The "nice weather" daily driver
  17. #15 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    Never Never Land
    The 97-03 cars didn't have pretensioner belts so you don't need to do anything with the wiring for the air bag stuff. There's nothing for the wiring to connect to on the car side. Just need to wire up power and ground for the power seat to work and the the two heat wires if you want the heat to work.
  18. #16 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    Oct 2014
    portland oregon
    Easy to do. I got my set of seats at pick n pull for 120 bucks on a discount weekend. Full price in my area is is 160.00. If i can do it you can to. Bring means to power the car and move the seat forward to gain access to the 15mm bolt.
    DO IT!
  19. #17 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    Nov 2016
    N. California
    Isn't there a passenger airbag switch?
  20. #18 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    Nov 2016
    N. California
    Quote Originally Posted by wowitsfast View Post
    DO IT!
    They're being shipped, we're going to do it.
  21. #19 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    Oct 2014
    portland oregon
    Sweetness. You wont regret it
    Seat covers availability - OEM or aftermarket, 2001 GTP? Attached Images
  22. #20 Re: Seat covers availability - OEM or aftermarket, 2001 GTP?
    Nov 2016
    N. California
    Your car looks nice. We only got the front seats, more of a practical concern. My son's GTP has a scraped-up passenger door. Although it is well-maintained mechanically, I'm afraid it won't get the level of cosmetic care yours received. I think my son will buy himself a Mustang or Camaro after college.
    Lifespeed
    2001 GTP
  1. Seat covers..
    By silly34 in forum 04+ Specifics
    Last Post: 10-17-2015, 04:52 PM
  2. Seat covers anyone?
    By 2001GrandPrixGeeTee in forum Visual/Body Modifications
    Last Post: 09-12-2012, 08:41 AM
  3. Car Seat Covers?
    By Frank217 in forum Visual/Body Modifications
    Last Post: 02-18-2011, 03:41 PM
