Thread: Need help with 0420 and 0128 code!!
Results 1 to 13 of 13
  1. #1 Need help with 0420 and 0128 code!!
    Jackson, Mississippi
    Hey guys I've bee having some trouble with the P0420 code (catalysts system efficiency below threshold bank 1.) I purchased a blue driver code reader/scanner to monitor the live data of the O2 sensors and they both seem to be working fine. According to my research o2 sensors should give voltage readings of 0 to 0.9 which I am getting according to the live data info. The Cat converter was replaced with a new one from the dealer about 2 yrs ago so I highly doubt its a bad cat. However i did research that the P0128 code (ECT sensor) can throw a P0428 code. Som my question I guess is how do you properly diagnose a 0420 code and 02 sensors for proper operation?
    Any and all suggestions would be greatly appreciated. Thanks
  2. #2 Re: Need help with 0420 and 0128 code!!
    Apr 2015
    Columbus, OH
    Monitor your coolant temp. What do you see when it's cold and warm?
    Top Swapped 01 Imp
  3. #3 Re: Need help with 0420 and 0128 code!!
    Kemmerer, Wyoming
    does your engine warm up like normal? if it doesn't then the thermostat is stuck open and that could cause a P0128 code. i've never heard of that causing an O2 sensor issue though
  4. #4 Re: Need help with 0420 and 0128 code!!
    I have noticed that my temp gauge is running 170-175 after driving for 30 minutes it’s not even close to the halfway mark.
  5. #5 Re: Need help with 0420 and 0128 code!!
    Oct 2012
    USA
    Quote Originally Posted by mcdavidhome View Post
    Regarding the P0420 code, I think the car computer compares the signals from the upstream and downstream O2 sensor to determine if the catalytic converter is effective. If the catalytic converter is working properly, the upstream O2 sensor should give readings that fluctuate and the downstream sensor should give readings fairly constant. This is because the car computer is constantly adjusting the air-fuel ratio, which leads to a fluctuating O2 from the exhaust. But the oxygen will be consumed in the catalytic converter when NOx and CO are burnt. I had a P0420 a few years ago after a misfire and I asked the shop to show me the O2 sensor reading from a GM Tech 2 reader. SO I would think a P0420 code actually point to a failed catalytic converter.
  6. #6 Re: Need help with 0420 and 0128 code!!
    Ok thanks. I think when I looked at the live data I did see the upstream sensor readings fluctuate but I also think the downstream were fluctuating also but not as much as the upstream o2. Its just hard to believe that my CAT is bad again becuz it was just replaced by the dealer under warranty about 2 years ago. But thanks for the info I will go back and compare the reading and send a screen shot if possible.
  7. #7 Re: Need help with 0420 and 0128 code!!
    Oct 2012
    USA
    Yeah, that seems to be pointing to the catalytic converter. I just think the catalytic converter in the Grand Prix is not that long lasting. For the fours years I owned my 2005 Grand Prix base model, I had two catalytic converter broken. At least a bad catalytic converter, unless it is clogged, is not going to influence how the car drives. If your state does not do emission test and you can live with a constant on check engine light, you should be able to drive the car just fine.
  8. #8 Re: Need help with 0420 and 0128 code!!
    Hey guys I have an update on the P0128 and P0420 problem I was having. As it turns out like you guys said the thermostat was stuck open thus causing the engine to not reach normal operating temperature which actually caused the P0420 code.
    The way I found out was by looking at the live data from my 02 sensors. The pre cat o2 readings and the post cat readings were very similar with the bad thermostat but after I replaced the thermostat the post cat o2 sensor reading changed dramatically. The wave
    form was almost flat which would indicate the Cat was doing its job by reducing emissions. I am honestly shocked at how many problems you can get from your engine not reaching the correct operating temperature. I really appreciate you guys helping me solve
    this problem.
    P.S. I tried to upload a screenshot of my live data so you guys can see for yourselves but was unable to because I exceeded the size limit by 25kb. I will see if I can shrink the image and try to post it later. Once again thanks for your help!!
  9. #9 Re: Need help with 0420 and 0128 code!!
    UPDATE!!!! Hey guys I have an update on the P0128 and P0420 problem I was having. As it turns out like you guys said the thermostat was stuck open thus causing the engine to not reach normal operating temperature which actually caused the P0420 code.
    The way I found out was by looking at the live data from my 02 sensors. The pre cat o2 readings and the post cat readings were very similar with the bad thermostat but after I replaced the thermostat the post cat o2 sensor reading changed dramatically. The wave form was
    almost flat which would indicate the Cat was doing its job by reducing emissions. I am honestly shocked at how many problems you can get from your engine not reaching the correct operating temperature. I really appreciate you guys helping me solve this problem.
  10. #10 Re: Need help with 0420 and 0128 code!!
    this problem.
    Dropbox - Bad thermostat..jpg - Simplify your life
    Dropbox - New thermostat..jpg - Simplify your life
  11. #11 Re: Need help with 0420 and 0128 code!!
    Apr 2015
    Columbus, OH
    Glad to hear! Yeah man, the ect effects many things in the computer. I often wonder how many good O2 sensors are in the landfills. I bet AutoZone has sold millions of new ones to folks that had the code, but the code was triggered to a different failing component.
    Top Swapped 01 Imp
  12. #12 Re: Need help with 0420 and 0128 code!!
    Thanks!
  13. #13 Re: Need help with 0420 and 0128 code!!
    Quote Originally Posted by Coldwaves View Post
    Yes my state does not do emission test and I could easily cut my CAT off but I'm afraid that without the cat I would get bad gas mileage due to the O2 sensor readings being off. I have heard some people say you can do the non spark fouler trick to get the o2 sensors to show good readings to fool the Computer but I don't know how reliable that is..
  1. 2001 grandprix gt p0446 code..no converter but no P0420 code...
    By chicagochuck in forum General Grand Prix Discussion
    Last Post: 12-13-2016, 01:59 PM
  2. Replies: 8
    Last Post: 02-21-2015, 07:08 PM
  3. HELP Needed! Car surging P0102 code and P1655 code im STUMPED
    By 97gtpjoe in forum General Tech Discussion
    Last Post: 02-06-2014, 12:15 PM
  4. '99 Grand Prix GT has code 1810, yet runs great as always, so why the code?
    By McFly1999 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 07:52 AM
  5. 0420 code
    Last Post: 03-01-2009, 12:24 PM
