#1
12V electric power failure
The 2001 GTP wouldn't start. The electrical system appears to be completely dead, but the battery is at 12.6V. When I probed the large positive wire on top of the fuse box behind the battery it reads 5V, but the reading is unstable. I haven't been able to find the schematic in the manual yet, but I'm guessing something between the battery cable and the fuse box has failed.
#2
Re: 12V electric power failure
GTP Level Member
10-28-2019
Check your grounds while your at it.. easy one under the battery.
Sent from my SM-N920V using Tapatalk
#3
update: looks like the smaller black cable from the battery to the underhood fuse box is rotted and intermittent. Can I buy a new cable assembly anywhere?
#4
GTP Level Member
10-28-2019
Nailed it lol.. I get that stuff from the junk yard lol..
#5
Update again (you can't edit posts?): $83 from GMPartsDirect 12157012 Positive Cable
#6
GTP Level Member
10-28-2019
Sounds steep to me. 5 bucks at the u pull it yard
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#7
Donating Users
10-28-2019
I thought you said black cable? That's a positive harness you linked.
Top Swapped 01 Imp
#8
wowitsfast
LOL, buying another rotted cable and spending an hour or two to install isn't the way I do car repairs. Even an old GTP.
#9
bandook
Yes and yes.
#10
Turbo is the way to go.
10-28-2019
Napa used to sell battery cables that are pre made in various length for both positive and negative, perhaps they still do.
I'd check there or at another parts store before buying a new cable from GM, if that is still an option. Even it I couldn't do that I would just make my own cable for like $20. Bulk wire from napa and new cable terminal ends are cheap.
GTP Level Member
10-28-2019
Lifespeed
Your in California I'm in Oregon cars here arnt all rotted out.. beat to crap yes but not rotted. Same where you live wires are typically in good condition since W-body's fill the yard.
No figuring required just go find a good one and take it home.
Or order it online wait for it to come. Or go by the parts and remake them to length.
#12
Thanks guys, I appreciate the money saving tips and I know these cars aren't worth a lot anymore. My son has been driving the car for a year, it will be 5 more years before he finishes college and can buy himself a better car. This GTP needs to last a while longer.
It doesn't burn oil, runs strong and has had regular transmission fluid changes it's whole life. We already rebuilt and FE5'd the suspension, fixed the supercharger drive, belts, water pump, radiator, MAF, brakes and a few other things. I'm OK with paying more for an OEM cable if it fits correctly and stays reliable while he's on his own focusing on school.
