Thread: E Brake
Results 1 to 10 of 10
  1. #1 E Brake
    Jun 2018
    Lehigh Valley
    I am having an issue with the e brake.
    Symptom: Pushing the e-brake pedal all the way to the floor and it won't grab.
    What I did so far:
    tightened up the cable under the rear of the car. (Helped a little and now the pedal only pushes about 4 inches or so)
    Replaced almost worn out pads (helped a lot more)
    Passenger side locks up tight
    Driver side tightens but I can still spin the wheel.
    What else could cause this?
    '97 Grand Prix GT Coupe
    '05 Grand Prix GTP Sport Red Metalic SOLD
    '05 Grand Prix GTP Silver
  2. #2 Re: E Brake
    Apr 2015
    Columbus, OH
    You might need to replace the rear section of the cable where it T's off to each wheel. They rust out, at least my car did. I think there is a bias adjustment in the rear section you could mess with first. The whole cable assembly isn't that expensive.
    Top Swapped 01 Imp
  3. #3 Re: E Brake
    did you use the adjuster star wheel to make the e brake pads about dragging the rotor when its put back on?
    the C clips that hold the cable ends in place at rear spindles also rust out, fall out and the cable is now slack and no brake on one side. i had the clip go bye bye, used a hose clampto keep it in place. been there 3-4 years now. my ebrake works like a champ.
  4. #4 Re: E Brake
    Jun 2018
    Lehigh Valley
    Ya, they were dragging when installed, but I'll have to test it again after driving for a bit. I'll also look for that c clip. Thanks.
  5. #5 Re: E Brake
    this fell apart, and the clip fell off, now theres a clamp on the rusty tube side the cable slide through. right side hooks to the e brake on that hook.
  6. #6 Re: E Brake
    With three cars and possibly two different ebrake setups available....I'm wondering is this a drum or caliper based ebrake? You mention replacing worn out pads, that'll only help if you have the caliper setup. In the 04+ with caliper setup IIRC there were a few folks that had to replace the caliper because the ebrake wasn't working properly in it. Not 100% sure though.
    If it's a drum setup, pull the disc and look at the horseshoe ebrake and replace if necessary or adjust via the hole in the backing plate like Scott mentions.
  7. #7 Re: E Brake
    Jun 2018
    Lehigh Valley
    Thanks for the reply. It was on my 05. Should have clarified.
  8. #8 Re: E Brake
    ahh, 05 has the cable to the caliper does it not?
  9. #9 Re: E Brake
    Jun 2018
    Lehigh Valley
    Yes it does
  10. #10 Re: E Brake
    Check that you are getting cable movement at both calipers. If one isn't holding.. I think that's a caliper replacement.... sorry to say
  1. Brake Job DIY
    By Zinister09 in forum General Grand Prix Discussion
    Last Post: 02-20-2015, 07:05 PM
  2. Brake likes to put out . . . noise and brake dust
    By barbschwartzer in forum Brakes/Suspension/Chassis
    Last Post: 02-01-2015, 12:46 AM
  3. Replies: 2
    Last Post: 07-20-2013, 08:25 AM
  4. brake parts to get for brake upgrade??
    By colindunn in forum Brakes/Suspension/Chassis
    Last Post: 01-03-2011, 08:59 PM
