Thread: OB2 scan tool
Results 1 to 20 of 29
  1. #1 OB2 scan tool
    Dec 2014
    TN
    Im look for the best budget abs scan tool any suggestions thanks
  2. #2 Re: OB2 scan tool
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Someone mentioned they pulled their ABS codes using a BAFX Bluetooth adapter and ChevroSys android app. I have both, but my abs isn't throwing codes so I haven't tried it yet.
  3. #3 Re: OB2 scan tool
    Quote Originally Posted by SaukRapids View Post
    i have that set up with a elm 327, i hooked it up to my tahoe and it read stored codes, i have no isses with it, but wanted to play, it also lets you clear history codes.
  4. Likes SaukRapids liked this post
  5. #4 Re: OB2 scan tool
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    I got 1 for about $100 from Harbor Freight
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  6. #5 Re: OB2 scan tool
    Dec 2014
    TN
    well im trying to find one that read abs beacause im trying to find which hub needs preparing
  7. #6 Re: OB2 scan tool
    Dec 2014
    TN
    Quote Originally Posted by cheatah faheatah View Post
    do you know which model it was
  8. #7 Re: OB2 scan tool
    be a cold day in hell before i bought anything electronic from HF.
  9. Thanks biglion thanked for this post
  10. #8 Re: OB2 scan tool
    Jul 2017
    macomb mi
    bludriver is pretty good chrisfix did a review on it
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  11. #9 Re: OB2 scan tool
    Dec 2014
    TN
    so harbor freight electronics is not good also do you have model number of yours also im tying to find which hub needs replacing
  12. #10 Re: OB2 scan tool
    ChevroSys Scan Free (OBD2 & ELM327 for Chevrolet) - Apps on Google Play the app its free.
    this is the blue tooth scanner i have, had it for years now. some have issues witht hem these days due to china knockoffs. so they get this one.
    USED BAFX ELM327 Bluetooth OBD 2 CAN V1.5 Scan Tool Android - OBD Reader 661799212113 | eBay
  13. #11 Re: OB2 scan tool
    Dec 2014
    TN
    ok thanks for help im sure their good for near future diagnostics
  14. #12 Re: OB2 scan tool
    for a free app, it damn good. it also does engine live data, and reads/clears codes, but i only played with the abs part of it.
  15. #13 Re: OB2 scan tool
    Dec 2014
    TN
    cool that model you recommended will i be able to find same one on amazon
  16. #14 Re: OB2 scan tool
    Dec 2014
    TN
    Amazon.com: New BAFX ELM327 Bluetooth OBD 2 CAN V1.5 Scan Tool Android OBD Reader / Scanner: Everything Else this is the one off amazon the same as the link you sent from ebay
    Amazon.com: BAFX Products Bluetooth Car Diagnostic OBDII Reader Scanner OBD Scan Tool for Android: Automotive and this is another model not sure if this one is the elm327 model
  17. #15 Re: OB2 scan tool
    Amazon.com: BAFX Products Bluetooth Car Diagnostic OBDII Reader Scanner OBD Scan Tool for Android: Automotive this is the your bottom link if get this one cause its 1/2 the price of the other one.
    the elm 327 is its own brand, this bafx one is another brand. bafx seems to work better these days.
  18. #16 Re: OB2 scan tool
    Dec 2014
    TN
    ok so which one would you prefrer i get i only check amazon because of faster shipping from you expirence i want the
    best one for info and detail and abs
  19. #17 Re: OB2 scan tool
    id spend a few more bucks on the bafx. like i said a lot of people had issues with the elm's not working right. its hit or miss really.
  20. #18 Re: OB2 scan tool
    Dec 2014
    TN
    oh i just notice they both say bfx in the description so are they the same or ,,,,
  21. #19 Re: OB2 scan tool
    yup only one is like 40 bucks.
  22. #20 Re: OB2 scan tool
    Mar 2019
    Va
    The bafx says u have to purchase torque pro does that mean torque lite wont read all the real time data and it says it doesnt read abs how did u get it to do that cause i need to pull mine
  1. Scan Tool not communication
    By indygrandprix in forum General Tech Discussion
    Last Post: 09-01-2013, 10:10 PM
  2. ABS Scan tool??? Please help!
    By craig1980 in forum General Tech Discussion
    Last Post: 12-01-2011, 10:58 PM
  3. scan tool
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2011, 12:48 PM
  4. best scan tool for $200 0r less
    By RICE KILLER in forum General Tech Discussion
    Last Post: 03-12-2010, 01:35 AM
  5. KR/scan tool
    By ldyzluvdis06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2008, 10:24 PM
