Thread: Harness and wiring information
Results 1 to 7 of 7
  1. #1 Harness and wiring information
    Nov 2018
    NJ
    Forgive me if this is in the wrong place on the forum but, I'm looking at removing the entire harness from the Grand Prix I have (03) and putting it in a fiero.
    I'm mostly concerned about the dash and bcm working correctly after I remove what I do not need ( namely everything for the rear doors, airbags, abs )
    Has anyone here messed around with the body harness?
    What kind of signal does the speedo need, or is it mechanical?
    Is there a way to remove the abs completely from the tune?
    Is there a non dual zine heater control that's a drop in?
    I'm sure I will encounter more stuff as I try to do it.
  2. #2 Re: Harness and wiring information
    If you pull the body harness that goes to the dash, the speedo should function with the grand prix cluster. The speed sensor is on the transmission.
    The BCM itself and ABS are not functions of the PCM, so neither prevent the engine/transmission from working. You can't tune the ABS out because it's not a function of that controller and is not required.
    You can't easily switch between dual zone and non dual zone controls, nor can you easily switch from the HVAC buttons itself if you are using the stock grand prix harness.
  3. #3 Re: Harness and wiring information
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Congrats on the fiero project! I'm working on one as well at the moment.
    I'm a little confused what you're trying to accomplish exactly. Are you trying to completely integrate your gp harness with your fiero and have all functions work?
    As far as the bcm, there's a few people who have integrated f-body bcms into fieros with a little difficulty. Not sure on the modern bcms how you'd go about deleting the passkey system, but I'm sure it's possible.
    There's a few options out there for the dash, but I'll need to know what exactly you're trying to do.
    Can't wait to see pictures!
  4. #4 Re: Harness and wiring information
    Nov 2018
    NJ
    Quote Originally Posted by wstefan20 View Post
    I'm thinking on replacing the entire Fiero harness with the GP harness, though it may be easier to buy a Firebird and use the harness from that to start ( then I can also have the dash to swap in)
    I bought the Fiero with more electrical problems then I realized. it started and ran, but would blow fuses and act strangely ( headlights up and down, wiper speed erratic, radio blowing fuses, intermittent brake light function.. etc) which made me dig into the harness a bit where I discovered damage from rodents, poorly placed zip screws, and what i assume was an after-market stereo install that went wrong and was mishmashed back to the factory radio.
    My original plan was to just 3800 swap and drive, but now that its winter i might as well fix everything I can.
  5. #5 Re: Harness and wiring information
    Aug 2017
    Raytown, MO
    Quote Originally Posted by falconlb45 View Post
    I've definitely been there! Good news is that the fiero body harness isn't all that complex.
    The issue will be that in order to keep factory power windows and door locks (If you have them) and other things that can't be moved over since they're physically part of the vehicle will basically have to be reverse engineered to make sure it'll work and how to integrate it.
    The easiest route by far is to swap the complete dash from an f- body and use it's bcm and steering wheel column if possible. With this approach, you'd simply have to adapt fiero body features to this harness, then adapt the engine harness to it.
    Being quite honest, I personally don't have the kind of time to engineer it for you, and if you're not familiar with reverse engineering wiring diagrams, this project will take years. Not to discourage you, but just laying out the truth.
    Of course, any small engineering things you get stuck on, I'd be willing to help here and there though!
  6. #6 Re: Harness and wiring information
    you can buy this harness pre made for like 400 bucks. pencocks fiero forum has a guy over there who makes and sells them.
  7. #7 Re: Harness and wiring information
    Nov 2018
    NJ
    For me, there is damage to my factory harness in several locations- to use the adapter harness I'd first have to remove my harness and repair it. And honestly if I'm doing all the work of removing the harness, I'd rather spend the time fitting a harness that wouldn't require an adapter at all. I'm also not sure the guy Jscott is still around
    Would this be as easy as taking the connectors from the fiero harness, Removing the connectors from the new harness and then replacing them with the Fiero connectors? I've never dove this deep into the wiring of a car.
    I've got two potential fbody cars in the wings, one is a 3.8 the other isn't- any idea how difficult it would be to get teh 3.8sc engine harness to play nice with the non 3.8 harness?
    I'm browsing some fbody forums and groups now, waiting for answers as well
  1. PCM Wiring Harness & Fuse Box Wiring Size
    By 98heritagegrandprix in forum General Grand Prix Discussion
    Last Post: 10-04-2017, 04:17 PM
  2. Need some help with 97 GTP ECM harness wiring
    By Mrroddavis2 in forum General Tech Discussion
    Last Post: 08-09-2017, 03:37 PM
  3. Speaker Wiring Information
    By Montypr20 in forum Audio, Security & Visual Electronics
    Last Post: 09-17-2013, 08:43 AM
  4. 06 Wiring Harness HELP!?
    By Springer09 in forum Audio, Security & Visual Electronics
    Last Post: 09-23-2012, 09:11 PM
  5. Need some help, wiring harness meltdown! have some harness swap questions for a guru
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 09:23 PM
