Thread: 2002 GP air conditioner condensation hose drain
Results 1 to 4 of 4
  1. #1 2002 GP air conditioner condensation hose drain
    Feb 2016
    North Carolina
    I have seen post online about where this hose is located but I am not finding it behind the alternator on passenger side as one post said or the other place one video showed , by where the air conditioner lines come in / out of firewall, on drivers side.
    I ask because on older cars I had ,a 94 T-Bird and an 86 Buick ,this line coming out of firewall was obvious, it was a short stub with an opening to let water out that you could see looking into engine area on firewall.
    Anybody know exactly where this hose is on my 2002 GP , is it hidden when looking from engine area by other hoses ,things . . . is it easier to get to from under the car or from engine area ?
    Al
  2. #2 Re: 2002 GP air conditioner condensation hose drain
    its very low on the firewall pass side, the rack kinda blocks it from view. up on ramps slide under the car you'll see the rubber hose sticking out.
  3. #3 Re: 2002 GP air conditioner condensation hose drain
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  4. #4 Re: 2002 GP air conditioner condensation hose drain
    Mar 2018
    NY
    You gotta feel around for that rubber 90 degree elbow on the firewall. I would say its probably down along the level where the power steering pump is. That's my best advice. Mine clogged up a few years ago and had to clean it out. I also cut the drain opening a little bigger and its been good since
  1. Condensation under oil cap
    By Madness in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2014, 10:15 AM
  2. Flush/Drain Coolant from Bottom Radiator Hose
    By kennn in forum General Tech Discussion
    Last Post: 07-08-2012, 03:56 PM
  3. Condensation?
    By Speedy1973 in forum General Tech Discussion
    Last Post: 05-15-2012, 09:56 PM
  4. 2002 Grand Prix power steering hose replacement.
    By ktom6 in forum General Tech Discussion
    Last Post: 06-29-2011, 10:31 PM
  5. radiator drain o-ring size? FAILED motormite drain.
    By alacran in forum General Tech Discussion
    Last Post: 04-03-2010, 08:16 PM
