03-19-2018
fire it up, take the oil cap off. then see if the sound is gone. if it is the pcv valve is clogged or blocked off somehow.
after the cap is off put your palm over the hole see if theres suction if so, right back at the pcv.
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
If the PCV ain't clogged, switch the A/C on. see if it goes away.
Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
WarStryker13's Google drive
... our lady of blessed exceleration, don't fail me now ...
Being it's intermittent, it's a rarity it keeps doing it at idle long enough to chase anything down, I have already switched AC on and off while I was driving when it was doing it with no change. Since I have a ton of spare parts, I went and switched out PCV to see if it will go away. We shall see, the old one did seem free when shaken, but doesn't mean it wasn't sticking.
Well swapping the PCV had no effect. Still does it intermittently. Seems a little more prevalent when first starting to drive when cold, but really unable to distinguish any real pattern or isolate the offending part.
Any other ideas?
Donating Users
03-20-2018
May be pulley or tensioner related? I'd look at it with the hood open, play with the throttle and see if you can tell where it is coming from. Use a stethascope or vacuum tubing to assist.
Chris B
2009 CX-9
** SOLD ** 2002 GT
03-20-2018
waupachino
Any other ideas?
didnt say to swap it, said to open the oil cap and see if it goes away. put your hand over the hole and feel for suction. under the pcv could be clogged up, or another passageway.
we hear this same sound after intercoolers are installed wrong and block a pcv hole up.
If it sounds just like that video, mine did that exact same thing intermittently only at idle forever before the alternator ate itself. Took the belt off and you could barely turn it.
Sent from my SM-G955U using Tapatalk
Scottydoggs
Got it. I understand what you're saying. Biggest problem I'm having right now is its not continuous long enough for me to chase down.
#10
Re: Guess this noise.
03-24-2018
also take the belt off, fire it up. hand spin all the pulleys. like others said, the alt can go bad water pump, ac clutch, any of them pulleys can go bad.
#11
I did check all the pulleys prior to this post. Only one seemed suspect and I changed it.
I did have a chance to chase it down for a little bit at idle and it really sounded like it was at the Supercharger inlet because I could hear it the loudest at the Air Filter. It's either that or the side cover of the Transmission.
#12
Ok, this thing has me chasing my Tail. I'm thinking it may be the AC Clutch/front plate. Haven't been able to confirm yet because it's still intermittent. There is no change if I take the Oil Cap off when it's doing it and also no change if I turn the AC on while it's doing it. So that's a little suspect.
#13
03-31-2018
Have you been able to use a mechanics stethoscope or something similar to try and narrow it down? I don't know where at in STL you are, but I have a mech. stethoscope in the garage that I use for this kind of stuff. I'd be more than happy to swing by and help out. I'm not overly familiar with the M90 cars but may be able to lend a hand. I HATE intermittent issues. I'd rather have the damn thing fail outright than just make a noise every now and then.
#14
FordMan77
No I don't have a stethoscope. I appreciate the offer, very nice. Thank you, but if be afraid of wasting your time if we could not get it to make the noise while you were helping. I went ahead and ordered a new AC Compressor. Couldn't pass up the deal for a new Delphi for $100.00. The current one has been on the car for close to 400K. Pretty sure it's the clutch/ bearings making the noise. Hope I'm right, but if not at least I'll know that part is new.
#15
Donating Users
04-02-2018
waupachino
A piece of vacuum hose can do the same thing.
Chris B
2009 CX-9
** SOLD ** 2002 GT
#16
04-02-2018
Bronco Boy
or a fat screw driver , or a long wood dowel placed to your ear and the part your trying to hear. amazing what you can hear.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#17
#18
04-02-2018
Well if you change your mind let me know. No sense beating your head against it. After 411K on my GP I've heard some really strange noises, lol. Some not so good but always fixable.
#19
Thanks for the help everyone. My guess ended up being right. My new AC Compressor arrived today an not a moment too soon. After driving home from work, went to try and start the car again to see if it would make the noise and the motor wouldn't even turn over. The AC Compressor clutch was pretty much locking up. Swapped out the Compressor and won't try to charge until I can get the AC Recharge kit here and pull a vacuum on the system.
#20
04-03-2018
Good deal! Question is was it the clutch or the compressor that locked up? The only reason I ask is if it was the compressor then you could have metal junk in the lines which would require a teardown of the A/C system to clean out the lines.
Don't forget to replace the accumulator while you're at it. Might want to consider the orifice tube also. Went through this last year with my GP and it was completely covered in junk to the point it wouldn't cool anymore. Bad thing is the tube is located in the line under the brake booster and is a PITA to get out.
