Thread: What can I do to replace the abs sensor wires?
Results 1 to 10 of 10
  1. #1 What can I do to replace the abs sensor wires?
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    2003 Grand Prix. 187,000 miles. New Moog wheel bearings. Both the ABS and low traction lights are on, been like that for some time. I tried to remove the wiring from some junkyard GP's, and noticed that the wires are very thin. Are they 18 or 20 gauge? Has anyone tried to run new wires from the ECBM to the connector on the wheel bearing for the front wheels?
  2. #2 Re: What can I do to replace the abs sensor wires?
    GTP Level Member
    Oct 2014
    Check rock auto. They sell new wire harnesses.
  3. #3 Re: What can I do to replace the abs sensor wires?
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I had the same issue. I tried the kit and it still didn't work. Ended up replacing the whole run with 16 gauge to be safe. I'd try the kit first though. Another thing to check is for corrosion on the ebcm connector itself. I had to replace a few terminals to get things to work, though that's an extreme case. Usually they can be cleaned just fine.
  4. #4 Re: What can I do to replace the abs sensor wires?
    have you had the abs scanned? or you just guessing and tossing parts at it?
  5. #5 Re: What can I do to replace the abs sensor wires?
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    Had ABS light for right front. Wire looked fine on the outside. It was broken inside the insulation. Bought the Dorman ABS wire kit, soldered in, no problems since. Pretty common problem on here.
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  6. #6 Re: What can I do to replace the abs sensor wires?
    Aug 2017
    Raytown, MO
    Yup! Though I completely agree with Scotty, it's much better to know what code you are throwing because the light can mean many different things. In addition to the wire, I also had to replace my module due to a second fault, so you could have more than one issue. Just better to be sure. I have a scan tool that can do abs/srs and more and I think I paid $100? Best money I've spent
  7. #7 Re: What can I do to replace the abs sensor wires?
    Jul 2010
    Coquitlam,BC,Canada
    Scan to find the location. Sounds like you need the "Help" wiring harness; either the wires rub through or the plug goes bad.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: What can I do to replace the abs sensor wires?
    Aug 2013
    Pittsburgh, PA
    I have not had the ABS checked out by anyone. With the mileage at 187,000 and with both ABS and traction control (on the DIC) being on, I figured I would just replace the ABS wiring (harness) as I have had the ABS/TC light come on before on the other GP's I owned.
    In my other high mileage GP (274,000 miles) I just pulled the bulb for the ABS and covered the traction control light with black tape. Been like that for 7 years.
    But, you raise good point that there could be more going on.
    I need to get some money together and buy a fully functional scan tool to that I can check things out on my own. It is pretty much against my religion to take any one of my GP's to a shop. All the shops around me don't seem to have a clue how to diagnose anything.
    I had no idea that Rockauto sold a harness for ABS, I will send for one of those.
    Thanks for the advice everyone!
  9. #9 Re: What can I do to replace the abs sensor wires?
    Jul 2010
    Coquitlam,BC,Canada
    You can pull the ABS fuse to shut the lights down, but this also disables the A/C.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  10. #10 Re: What can I do to replace the abs sensor wires?
    Aug 2013
    Pittsburgh, PA
    I was installing winter tires a few weeks ago, and I saw that the ABS wire was completely pulled off of the right side wheel bearing. That particular wheel bearing is not worn out. I'm not replacing it just to get the ABS and trac light to go off.
    I removed the gauge cluster and took out the bulb for the ABS and took black electrical tape to cover the trac light on the DIC.
  1. How to replace a crank sensor
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 08-08-2017, 06:21 PM
  2. Fix/Replace MSD Wires or back to ACDelco?
    By UCF04GPGTPCompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2013, 11:40 PM
  3. Oxygen sensor wires
    By chrisLB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2013, 06:24 AM
  4. Should I replace oxygen sensor?
    By GrandprixSteve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-13-2012, 07:49 PM
  5. P0135 - replace o2 sensor?
    By dirtmaster88 in forum General Tech Discussion
    Last Post: 12-08-2010, 04:08 PM
