Thread: No backup lights
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: No backup lights
    GTP Level Member
    Jun 2016
    Cleveland ohio
    The license plate bulbs do work fine.
    -Scotty, I think the 04+ might have a different routing. I do not see what you are talking about on my car. I traced the wiring until the rear speaker deck. I need to remove the seat to get to the rest of the harness. I know it runs under the side moldings. Its been too cold and snowy to have the car torn apart. It is supposed to be a bit warmer this weekend.
    Is there a switch at the gear selector that triggers the backup lamps? I may remove the center console to check if something there is all gunked up.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #22 Re: No backup lights
    theres got to be a plug you you cant take the trunk lid off with out cutting the wires. it could be wrapped in black tape.
    if your not seeing the plug, just open the loom up and look for a damaged wire. the damage is where the hinge likely touches the wire loom.
  3. #23 Re: No backup lights
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I have an update on this issue. long story short is the led bulbs were in the wrong way. :/ lol. Thanks again for all the the help guys!
  4. #24 Re: No backup lights
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Yup. Would've mentioned to try that if I knew you were using leds and that it started when you swapped bulbs. Leds are light emitting Diodes. Diodes allow electricity to go one way. Therefore, they only work in one direction. Glad you got it working though
  5. Likes rickisrad liked this post
  6. #25 Re: No backup lights
    Nov 2012
    Madison
    How many GPers does it take to change a light bulb.
    Too funny man.
  7. Likes Bronco Boy, Scottydoggs liked this post
  8. #26 Re: No backup lights
    Mar 2015
    Tampa, FL
    I needed this diagram earlier, but where is the back up lamp relay located at?
  9. #27 Re: No backup lights
    GTP Level Member
    Jun 2016
    Cleveland ohio
    It is a fuse in the engine compartment fuse box. It is labeled auxiliary
  1. installing backup camera
    By Harbinger207 in forum Audio, Security & Visual Electronics
    Last Post: 07-14-2017, 04:19 PM
  2. Backup camera
    By Paul007 in forum General Grand Prix Discussion
    Last Post: 05-31-2016, 11:29 AM
  3. LED DRL's as backup lights?
    By TateBongard in forum General Tech Discussion
    Last Post: 09-12-2014, 08:57 PM
  4. No backup lights, trunk release and fuel level is always reads full
    By dhallstead in forum General Grand Prix Discussion
    Last Post: 09-08-2013, 12:31 AM
  5. electrical help no trunk release, backup lights
    By BIGGRASS in forum General Tech Discussion
    Last Post: 08-03-2009, 06:53 PM
