Thread: L26 swap
Results 1 to 9 of 9
  1. #1 L26 swap
    Dec 2015
    albuquerque NM
    Need help
  2. #2 Re: L26 swap
    Are you going to expand on that?
    I can't help you if you don't provide the stuff you are having trouble with.
  3. #3 Re: L26 swap
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Lol agreed!
  4. #4 Re: L26 swap
    Dec 2015
    albuquerque NM
    Hi,thanks for responding, I'm just swapping upper intake plenum, already have the TB adapter from zzp,and I'm about to order the EGR blockoff plate from eBay,so that being said I'm also planning to put a breather on the sticking stove pipe top of plenum,I just unsure how to router the rest vacuum lines,I'm swapping from plastic to metal(aluminum)
  5. #5 Re: L26 swap
    Aug 2017
    Raytown, MO
    Yup. That's what I'm currently running on my L36 n/a along with several other members here. The rear vacuum for your brake booster is the same, as well as all your other vacuum lines. I had to remove my evap from the mount to pull things further forward to compensate for the longer neck, but all the electrical reached fine. You could also just extend the evap vacuum lines and electrical if you wanted to make it look more "stock". Nothing else special other than dealing with the air intake, but I run a cone, so no problems there. Just went by home depot and got a 4" pvc pipe, 4" rubber 90 degree elbow, and put it on with a hole for the AIT sensor. That simple! Good luck and feel free to ask if you have any questions!
  6. #6 Re: L26 swap
    Dec 2015
    albuquerque NM
    Thanks,but what I'm doing is blocking off EGR hole in aluminum plenum keeping the existing egr and putting a breather in sticking up stove pipe,so now I have to figure out the trottle body vacuum line
  7. #7 Re: L26 swap
    Aug 2017
    Raytown, MO
    Yup. That's what I was referring to. Those vacuum lines on the front go to the evap solenoid and the fuel pressure regulator. Again, you don't have to re-route them at all, just unmount the evap solenoid so you can pull the lines forward is all.
  8. #8 Re: L26 swap
    Dec 2015
    albuquerque NM
    All right,good idea,thanks a lot,and HAPPY HOLIDAYS
  9. #9 Re: L26 swap
    Aug 2017
    Raytown, MO
    You too! And good luck! We all enjoy pictures of good work, so feel free to post up when you're done!
  1. Engine swap / Trans swap 2001 gtp v. compatible years
    By Banana Hammock in forum General Grand Prix Discussion
    Last Post: 07-06-2016, 08:27 AM
  2. Tuning Issues, 04 GT (L32 Swap / Gear Swap)
    By RivMan in forum PCM Tuning
    Last Post: 09-12-2013, 08:37 PM
  3. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  4. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  5. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
