Thread: Rtv on gaskets
Results 1 to 8 of 8
  1. #1 Rtv on gaskets
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Just wondering whether or not you guys use RTV or sealant on the intake end cap and also the oil filter adapter gasket??
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #2 Re: Rtv on gaskets
    Kemmerer, Wyoming
    I use rtv on my end cap gasket, I'm not sure what difference it makes, but in my head I like doing it because when I open up the coolant passage, almost always I nick the outside edge.
  3. #3 Re: Rtv on gaskets
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I'll put a thin layer of thermostat housing sealant on the end cap seal. I didn't open it up as much as some people do. I'll do some more searching on the filter adapter gasket.
  4. #4 Re: Rtv on gaskets
    The filter housing gasket can go on dry.
  5. #5 Re: Rtv on gaskets
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Thanks 5FDP and SGT. I looked up on the Felpro website and they said install the adapter gasket dry as well.
  6. #6 Re: Rtv on gaskets
    SE Level Member green97's Avatar
    Jul 2011
    Eastern Idaho
    I used to spread a thin layer of silicone type gasket maker on a lot of gaskets probably due to a lack of confidence. Then started using this spray tack stuff...
    https://www.napaonline.com/en/p/BK_7651224
    It works really well and its not messy as long as you have a piece of cardboard or something to lay the gasket on and spray it. I recently resealed my entire motor and the only gasket maker I used was on the intake corners. No leaks so far.
    Intake stuff near the throttle body is usually installed dry. I used the spray on the oil filter adapter.
  7. #7 Re: Rtv on gaskets
    Quincy, Mass
    I use rtv instead of a supercharger gasket. I did the end cap seal with just rtv because I went a too close when I opened up the coolant flow, no problems. Oil filter adapter i always do dry, with ptfe paste on the bolts.
    No more GP 04 Impala SS Indy:
  8. #8 Re: Rtv on gaskets
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Thanks guys! I went dry on both and I did use the PTFE paste on the adapter bolts.
  1. used set of lim gaskets
    By SgtMarshal in forum Wanted To Buy - Parts
    Last Post: 07-28-2017, 04:47 PM
  2. Double SC gaskets, no gaskets, gaskets and RTV, what do?!? (Intercooler) Vac Leak
    By 01Blackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2014, 06:36 PM
  3. LIM Gaskets?
    By SuzukiGS750EZ in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-30-2014, 02:17 PM
  4. Best LIM Gaskets to Use on 3.8 GT
    By indygrandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2013, 05:57 PM
