Stalled while driving city speed
- engine would crank but no start
- approx. 5 minutes later it fired
- drove 3 blocks and it did it again
- waited approx. 10 mins and it fired
- drove 500 feet and stalled again
- sat for 30 mins (turning ignition over every 5 mins or so)
- after approx 30 mins it fired and was able to the 30 minute drive home in 3rd as rpm
was fluctuating and I assumed maybe CPS.
I checked the codes with my basic obd2 scanner and it said there was no data in computer and there were three tests flashing on the screen indicating they hadn't been completed. I have not disconnected the battery at any time.
Following Day:
- changed crank position sensor
- car started and ran seemingly fine
- went for a short drive and returned leaving car running in park in the driveway
- returned to car after approx 10 minutes and put it in reverse
- as soon as I put it in reverse the car died again, this time "no crank"
I then had a mechanic look at it (after hours at his home garage)
- the computer was checked for corrosion and seemed clean
- relays were checked and cleaned, are all good
- computer was reset by tapping neg and pos battery cables (not connected to batt)
- wiring in fuse/relay box was checked for corrosion and all was clean
The car started after playing with all of this and the mechanic assumed it may have been a dirty relay. I picked the car up from him and drove home with no issues. The car sat shut down for 30 mins. I then started it with no issues, backed out of the driveway, put it in drive and got about 20 feet and it died again. Tried to restart but, once again, no crank. I pushed it to the side of the street and parked it for the night.
The Next Day:
- engine started without issue
- I drove up and down the curb side, forward and reverse, for about 10 minutes
- the car stalled in reverse but was able to restart
- engine ran for approx. 30 seconds after I put it in reverse then died again
- once again, now No Crank.
AND THATS IT...lol. Any ideas?
Thanks in advance.
