I've searched everywhere and can't find an answer. You guys have helped me out a ton in the past. I have an 06 GP, and have a coolant leak I can't locate. I just changed the radiator out as it had a major leak. I started noticing coolant missing after everything was back together. The leak seems to be coming from behind the motor on the passenger side, all I can see is it leaking on the floor from under the car. It doesn't leak until there is a pressure, I did a pressure test and confirmed it, and all hose connections are fine. I already have metal elbows so it's not that for sure, and my heater core is bypassed currently, no leaks from the bypass hose. Water pump is not leaking, and lower radiator hose is fine. I noticed some coolant on a drip pan prior to my radiator failing, so it's possibly been around for a bit. Any help would be appreciated, thank you again.
