I was measuring an 8-rib ATI balancer and I believe the distance from the accessory belt to the first rib on supercharger is the same distance as a stock harmonic balancer.
I then measured a stock pulley versus a ZZP pulley, they are set up run a 6-rib belt in the middle of there 8-rib pulley.
So if I run a ATI balance and a ZZP pulley I need to space out the ZZP pulley 0.141" (1 rib dimension) to get the 8-rib to align.
