Thread: Another low beam headlight issue. Please help.
Results 1 to 20 of 30
  1. #1 Another low beam headlight issue. Please help.
    Dec 2016
    Texas
    So I just bought a 2007 grand prix gt about a month ago. So last week the low beams just quit working. I've replaced the relay,bulbs,and headlight switch. As far as I can tell I'm not getting power to the relay box. High beams work, all blinkers work. DRLs work. Fog lights even work. Checked all fuses and were good. Replaced all headlight fuses anyways. I'm stumped. Any suggestions on what to look for or where would be greatly appreciated.
  2. #2 Re: Another low beam headlight issue. Please help.
    Did you replace the HDM module/relay?
    That's a pretty common failure on the 04+ cars.
  3. #3 Re: Another low beam headlight issue. Please help.
    Dec 2016
    Texas
    Yep, first thing I did. Forgot to mention this. I pulled the headlights and found the brights to be spliced into the low beams so that they were forced to turn on when you toggle brights.
  4. #4 Re: Another low beam headlight issue. Please help.
    SWPA
    Highs come on with lows from the factory on 04+. That is not your issue.
    Check for power at the harness. I had a harness get hot once and it would intermittently lose contact. I replaced the harness and all was well.
  5. #5 Re: Another low beam headlight issue. Please help.
    Dec 2016
    Texas
    Well after I took the splice off the the two wires the low beams won't even light up with brights. Which harness? Do you have a link for one?
  6. #6 Re: Another low beam headlight issue. Please help.
    SWPA
    The plug in that the bulbs themselves plug into.
  7. #7 Re: Another low beam headlight issue. Please help.
    Dec 2016
    Texas
    Even though they seem fine?
  8. #8 Re: Another low beam headlight issue. Please help.
    SWPA
    Check for power there, then work backwards. Find out where you lose power at and go from there.
  9. #9 Re: Another low beam headlight issue. Please help.
    Dec 2016
    Texas
    I im not getting any power from the relay. And have changed the relay.
  10. #10 Re: Another low beam headlight issue. Please help.
    SWPA
    Are you getting power to the relay? Are you sure you checked/changed the right relay?
  11. #11 Re: Another low beam headlight issue. Please help.
    Dec 2016
    Texas
    I'm 100% positive relay has been changed. I'm also positive the relay isn't getting power. #35 hdm module
  12. #12 Re: Another low beam headlight issue. Please help.
    Dec 2016
    Le Sueur
    So of relay isn't getting power where do we go from there ? I'm in the same situation also
  13. #13 Re: Another low beam headlight issue. Please help.
    Dec 2016
    Texas
    So I thought about hot wiring a dummy switch into both lights to limit power to the outside light. While splicing the high beam back to the low beam. So that I can keep high beams on, and use the two dummy switches to toggle the "actual brights" if that's making sense to anyone.
  14. #14 Re: Another low beam headlight issue. Please help.
    Quincy, Mass
    Could this be a bcm issue?
    No more GP 04 Impala SS Indy:
  15. #15 Re: Another low beam headlight issue. Please help.
    Dec 2016
    Texas
    How could I check? I've worked in a variety of cars and tbh this is the weirdest problem I've ever worked on lol luckily local law enforcement was nice the other day and let me go with a warning!
  16. #16 Re: Another low beam headlight issue. Please help.
    SWPA
    For the time being you could actually put your high beam bulb in your low beam part of the headlight and just keep your headlights on high beam, but they will be "muted" due to the cover part of low beam lense. I did that when my HDM module crapped until I could get a new one.
  17. #17 Re: Another low beam headlight issue. Please help.
    Dec 2016
    Texas
    I'll definitely try that for the time being, thanks a bunch!
  18. #18 Re: Another low beam headlight issue. Please help.
    Dec 2016
    Texas
    So how to I get a new bcm? Should I just go to the dealership?
  19. #19 Re: Another low beam headlight issue. Please help.
    Aug 2016
    CT/RI Border
    Could it be the headlight switch itself in the column? No power to the relay, that would be where I start before the BCM.
    Sent from my ASUS_Z00TD using Tapatalk
  20. #20 Re: Another low beam headlight issue. Please help.
    Dec 2016
    Texas
    I replaced the headlight switch already. Bcm is there only thing I haven't touched
  1. Having a problem with 2008 GXP 5.3L Low Beam Headlight Socket. Help??
    By arod812 in forum General Tech Discussion
    Last Post: 12-25-2014, 01:24 AM
  2. Low Beam issue
    By Stephen Bernier in forum General Tech Discussion
    Last Post: 10-12-2012, 06:02 PM
  3. Low Beam Issue
    By Andrew Nelson in forum General Grand Prix Discussion
    Last Post: 06-02-2012, 12:19 PM
  4. Headlight Problems (Low beam)
    By nrfitchett4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2011, 12:40 PM
  5. New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    By GeddyLee in forum General Tech Discussion
    Last Post: 01-29-2009, 07:26 PM
