Thread: Radiator decision question
Results 1 to 20 of 21
  1. #1 Radiator decision question
    Jun 2016
    USA
    Hi Guys. I need a new radiator for my 05 GTP and looking around I found this one on Ebay. Being inexperienced at buying parts, I wonder if anyone could tell me if this would be a bad choice and I should go get one from RockAuto.
    If RockAuto is the answer, which one of these would be considered reliable? I don't have any mods on my car, other than shiny metal valve covers from ZZP.
    Any advice would be greatly appreciated.
  2. #2 Re: Radiator decision question
    i got one for 52 shipped iirc off ebay, they work fine.
    you swap the low coolant sensor over and if your cap looks old replace it.
  3. #3 Re: Radiator decision question
    GXP Level Member suitercrew's Avatar
    Oct 2015
    I got one of eBay too and it's worked out fairly well. For some reason the transmission lines kept unscrewing them selves in which I was leaking fluid but after some loctite everything else is A+
    Sent from my LG-H901 using Tapatalk
  4. #4 Re: Radiator decision question
    Quincy, Mass
    Be careful, a lot of places say it's for a gtp/supercharged option but they are the gt radiators which are thinner. Make sure you check thinkness before ordering. For example that eBay one makes it seem as though it's a 1" think radiator by the tittle but in the description it says it's a 5/8" core.
    No more GP 04 Impala SS Indy:
  5. #5 Re: Radiator decision question
    and that dont matter one bit, buy what ever you find for the right price. my car came with a 1 inch, its got a 5/8's now and nothing changed at all. temps are the same.
    and good luck finding the one inch for a fair price too.
  6. #6 Re: Radiator decision question
    Quincy, Mass
    What I'm saying is if you want a 1in make sure it is what it says it is. I don't want to pay for a 1" only to get a 5/8" you know
  7. #7 Re: Radiator decision question
    Oct 2015
    Ya or just order the specto performance radiator that 1" of amazon for 100$ shipped
  8. #8 Radiator decision question
    Quincy, Mass
    If you mean this one then it is not 1", if I remember right it's 5/8"
    Spectra Premium CU2710 Complete Radiator https://www.amazon.com/dp/B000C7VZ8W..._tXvvybG7710DW
    Yup found it on summit
    https://m.summitracing.com/parts/sgt-cu2710
    Found a 1in and a spectra 1in on summit
    https://m.summitracing.com/parts/osc-2862
    https://m.summitracing.com/parts/sgt-cu1890
  9. #9 Re: Radiator decision question
    being the 5/8 rad works just as well as the 1 inch, id save all that money and got 50 shipped off ebay.
    my car came with a 1 inch, now has the 5/8, not a single degree hotter does it run. same temps. aka save the money.
  10. #10 Re: Radiator decision question
    Quincy, Mass
    Isn't that because of the fans though. So having a 1in would cool down quicker and then save life on the fans?
  11. #11 Re: Radiator decision question
    May 2008
    Schuyler, NE
    Not necessarily cool down quicker, but increased capacity for heat transfer before the fans need to kick on. It helps a lot in the hot and humid southern states during summer, especially if you have a heat exchanger blocking flow to the radiator.
  12. #12 Re: Radiator decision question
    Omaha, NE
    Stock is 5/8" for N/A and 7/8" for an L67.
    The Oversized vendor radiators are 1.4" for a 97-03 and 1.25" for 04+
    The 97-03 radiator upgrade is rumored to be from a 96-ish w-body
  13. #13 Re: Radiator decision question
    Quincy, Mass
    I think it was from the regals of that generation.
  14. #14 Re: Radiator decision question
    May 2008
    Schuyler, NE
    I'm almost positive it was from the cars with the 3.4 dohc motors. Lumina z34, Grand prix gtp, and whatever else those motors came in.
  15. #15 Re: Radiator decision question
    Jun 2016
    USA
    Thanks guys. I hadn't noticed the one I linked said 5/8ths in the info, going just on the title, so I went ahead and got the Spectra from Amazon.
  16. #16 Re: Radiator decision question
    Jul 2012
    Clayton,NC
    96 monte carlo 3.4
    1 1/4 inch for $90 on rockauto.
    98 gtp- cammed intercooled slowness
  17. #17 Re: Radiator decision question
    GTP Level Member
    Jun 2016
    Cleveland ohio
    If you plan on modding further get the correct 1" radiator. It will have more transmission cooling capacity also. I don't have a lot of money but I'm also not a cheap a$$. Put what it calls for in it.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  18. #18 Re: Radiator decision question
    Quote Originally Posted by rickisrad View Post
    no it wont, the tanks are the same size, where the tranny cooler is.
    all my temps are the same as before with a 1 inch.
  19. #19 Re: Radiator decision question
    GT Level Member willie14's Avatar
    Jun 2016
    westland mi
    Their are a couple of oversized zzp aluminum radiators in the for sale section. I'm sure u can get um for a sweet deal seein as how they've been posted for awhile...
    98 Grand prix SE to GTP conversion( in works). Full body conversion in works, drilled n slotted rotors, ceramics, all new suspension, custom CAI, NGK wires/Vpower plugs, SD headers, 180 Tstat, AND A WHOLE BUNCH OF PAINT BABY!! Tuned by E&J performance.
  20. #20 Re: Radiator decision question
    GTP Level Member
    Jun 2016
    Cleveland ohio
    You are correct. Both transmission cooler cores are 11 1/2 inches. Sorry.
    I guess the choice is whatever he feels like spending the money on. I personally put at least what was supposed to be in there. If money is tight though, the smaller one would work
  1. Radiator fan question
    By chris99gtp in forum General Tech Discussion
    Last Post: 06-19-2016, 09:32 PM
  2. Radiator Upgrade Question 97-03 GP
    By 01Blackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2014, 07:16 PM
  3. radiator question
    By jakeb157 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2013, 06:28 PM
  4. Radiator Hose Clamp Question
    By LeadfootCJ7 in forum General Tech Discussion
    Last Post: 02-20-2013, 03:20 PM
  5. Radiator Mount Question
    By TheManiac in forum Brakes/Suspension/Chassis
    Last Post: 12-13-2011, 05:57 PM
