Thread: Front end shaking while acceleration
Results 1 to 8 of 8
  1. #1 Front end shaking while acceleration
    Dec 2016
    Iowa-IA
    Friday I noticed a bad vibration in the from end. Took drivers front tire off and didn't see anything so i put the tire back on and drove with no issues for 40 miles. Ran codes and it said the front bearings were bad so I replaced both. Car drove great for about 75 miles, smooth as could be, then the vibration came back. Only vibrates when I am on the gas, quits as soon as I let off the gas. Noticed a little play in the passenger cv shaft but was told it's not bad enough to cause any issues.......? It's a 2006 grand prix gt, stock. Please help
  2. #2 Re: Front end shaking while acceleration
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    I'd guess cv shafts. Same symptoms I had when mine went.
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  3. #3 Re: Front end shaking while acceleration
    Enfield, CT
    CV.
  4. #4 Re: Front end shaking while acceleration
    Dec 2016
    Iowa-IA
    Quote Originally Posted by HighOctaneRacing View Post
    CV.
    Do you have to separate the ball joint to get the cv shaft out?
  5. #5 Re: Front end shaking while acceleration
    Yes, if you choose to do it that way.
    It's the best way to insure you don't mess up the front camber somehow. Some will remove the strut from the knuckle but the ball joint way is the better way to me.
  6. #6 Re: Front end shaking while acceleration
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    I had the same vibration. Replaced the passenger axle. Same thing. Ended up replacing the drivers and and when I was pulling it out it all fell apart. That fixed the issue.
    Also, apparently NAPA reman axles use stock axles as a core so that's sorta good instead of getting junk Chinese stuff.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  7. #7 Re: Front end shaking while acceleration
    GTP Level Member
    springfield IL
    after changing a cv shaft do you need to get an alignment...???
  8. #8 Re: Front end shaking while acceleration
    If you do it the ball joint way, no you do not need too.
    If you remove the knuckle to strut bolts and don't get it back exactly where it was before you can throw it out of alignment sometimes.
  1. Front End Shaking/Vibrating
    By CleanGP in forum Brakes/Suspension/Chassis
    Last Post: 07-18-2015, 12:25 PM
  2. 2002 grand prix gt shaking on acceleration
    By Jonarin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-05-2015, 12:02 PM
  3. Shaking during slight acceleration
    By zeppelin913 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2011, 11:55 AM
  4. Shaking on light acceleration
    By zildjian102 in forum General Tech Discussion
    Last Post: 04-25-2011, 09:56 PM
  5. Terrible Shaking upon acceleration only
    By Vale in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-03-2010, 08:09 PM
