Thread: Service engine soon light
Results 1 to 11 of 11
  1. #1 Service engine soon light
    SE Level Member the955iman's Avatar
    Feb 2009
    Griffin, GA
    Mine came on today. I have a 98 GTP. I'm thinking sensor, but not sure.
    Is there a way to get a code without going to have it read? On my Jeep, I can turn the key on and off 5 times and it will give me a blink code. Is there a way to do this on the Grand Prix?
  2. #2 Re: Service engine soon light
    Oklahoma
    That must be an older Jeep. On the OBD-II systems that is in your 98 GTP, I dont know of anyway to do such a things. Your best bet is to take it to a place such as Autozone and they will read codes for free and give you the definition of them and then you post that up here and we can see what else we can come up with anything if needed.
  3. #3 Re: Service engine soon light
    Feb 2009
    Griffin, GA
    Thanks for the info.
    It is an older Jeep, 1996
  4. #4 Re: Service engine soon light
    Oklahoma
    My wife has a 1996 Jeep as well and I dont think I can retrieve the codes in the way you mentioned. However, 1996 was the first year for ODB-II and some vehicles that year had ODB-II and some still had the older ODB-I. The ODB-I systems you could retrieve in the way you mentioned or using a shorting clip on the ALDL interface connector.
  5. #5 Re: Service engine soon light
    Feb 2009
    Griffin, GA
    Mine is 96 Cherokee Sport, aka. The Turd.
  6. #6 Re: Service engine soon light
    Feb 2009
    Griffin, GA
    It's also worth noting that the car shows no other symptoms. Runs fine, idles fine, all other gauges are good. Just came on while sitting traffic.
  7. #7 Re: Service engine soon light
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    that trick should work on dodge/chrysler vehicles made before 2001
  8. #8 Re: Service engine soon light
    Feb 2009
    Griffin, GA
    Huh. The light went back off today. Thinking it may be an O2 sensor.
  9. #9 Re: Service engine soon light
    Oklahoma
    No, it wouldnt go off on its own like that unless it sees no further trouble. Depending on the code, it can take up to three drive cycles (cold starts, complete warm up and cool back down) before the code will clear on its own if the trouble is no longer detected. Ive never seen an O2 go off on its own like that. Not saying it cant happen but its rare. Typically once they truly go bad, they're done for.
  10. #10 Re: Service engine soon light
    Feb 2009
    Boston
    I'm not sure as to why.. but sometimes if the gas cap isn't on tight, the SES light will come on. This can happen with all OBDII cars... mine came on the other day after my first fill up in my new car and went off 5 minutes after pushing it in right and a quick drive around.
    Fiske
    95 Taurus SHO ATX - 121K
    99 Audi 2.8 Quattro - 113K
    99 Grand Prix GT - 83K
  11. #11 Re: Service engine soon light
    Barksdale AFB, LA
    Quote Originally Posted by GTFiske View Post
    Because a gas cap that isn't tight becomes a pressure leak in the EVAP system. The systems diagnoses itself and if it detects a pressure leak it will set a code. Tighten the cap, pressure leak goes away.
    2009 Subaru Impreza WRX STI
  1. Engine light came on what to do?
    By jasonball in forum General Tech Discussion
    Last Post: 12-03-2008, 03:44 PM
  2. *ERROR CODE INSIDE* Installed new PCM - Service engine light is on
    By Freebeer187 in forum General Tech Discussion
    Last Post: 11-23-2008, 07:05 PM
  3. check engine light
    By cboth686 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2008, 08:48 PM
  4. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 10-08-2008, 10:31 PM
  5. Service Engine??
    By wrfdff4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 11:55 AM
