Thread: New half shaft clunk
Results 1 to 11 of 11
  1. #1 New half shaft clunk
    SE Level Member klimtrack's Avatar
    Sep 2014
    ChiTown
    I've replaced drivers side half shaft year ago with A1 Cardone unit which failed after a year minus 5 days. Started to vibrate under accel and made this metallic clunk when going from drive to reverse and vice versa. So I sent it back - lifetime warranty, no more vibration but the clunk is still there. Could it be the new half shaft is garbage or...is my trans starting to act up? It has zero issues as far as shifting/slipping, fluid is nice and red no funky smell or anything. Came across this video on YT, exactly what my car does/sounds like. Any suggestions?
    2002 Regal GS
  2. #2 Re: New half shaft clunk
    SWPA
    Reverse to drive clunk should have nothing to do with the axle shaft. I'd bet you've got a motor mount sh!tting the bed.
  3. #3 Re: New half shaft clunk
    Sep 2014
    ChiTown
    I should probably be more specific. When changing gears from reverse to drive all is good. When I change gears from D to R and accelerate I get this metallic pop. I can hold my foot on the brake throw it in reverse give it some throttle - POP, put in in drive and do the same thing - POP. Just like in that video I posted, even the sound is exactly the same. Mount?
    2002 Regal GS
  4. #4 Re: New half shaft clunk
    SWPA
    Yes, sounds like the mount to me.
  5. #5 Re: New half shaft clunk
    GTP Level Member
    Jun 2016
    Cleveland ohio
    It would be better if the video was of your actual car. I had that type of clunk with the same symptoms. It could be a mount like said above. I eliminated all possible issues. I checked all my mounts. They are all solid and urethane so I figured that wasn't the issue. I tightened all subframe bolts, rack and pinion mounting bolts, re torqued the axle nuts and make sure they were seated properly. Just anything under the car I tightened. In my situation it turned out to be the aftermarket axles didn't work very well in my car. I bought a brand new AC delco shaft and the noise stopped.
    In my 04 NA GT I had this issue also. Again same checks but different problem causing the clunk. In this situation it was the lower ball joint (new mevotech) was making the clunk. I had someone power brake the car going back and forth in reverse and drive and looked around under the car until I could isolate where the noise was coming from. No matter how much I tightened the nut it still shifted enough to clunk. I put a Moog in there and it stopped.
    You just have to go through the process of elimination.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  6. #6 Re: New half shaft clunk
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    FWIW I had this same "clunk" on my regal for several years. It was the wheel bearing. When you put the axle in what did you torque the nut to? Even though I went through about 7 passenger wheel bearings in the past 6 or so years. Timken, and other various manufactures all had the same clunk. I have a video on youtube if you want to. Look up "popping sound from my regal". It only happened when going from park to reverse after the car sat for a few minutes and settled.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  7. #7 Re: New half shaft clunk
    Nov 2011
    NY
    Posting a video of an Audi to diagnose a Grand Prix problem is pretty counterintuitive... Just saying. As mentioned, take a video of your actual car, actual noise, open Photobucket account or similar and then post it. That said, noise is a funny thing, it travels. But for the most part, imo, if the Trans was clunking as you say, you'd notice other tell tale signs of problems, not just a clunk. As for the clunk, there are ways to tell what they may be, ways to check ball joints and other attachment parts which may be responsible for the clunking. For the matter though, the Cardone axles are known to be junk, but people don't mind because of the lifetime warranty and lifetime of replacing them. Get a Napa next time, lol. Ball joints are cheap, and mounts are too. You neglect to state your mileage or other pertinent information regarding the condition and or age of your suspension. It could be a broken sway bar end too, that's known to happen... Lol. So please be more specific and you'll probably get a better internet diagnosis ; )
  8. #8 Re: New half shaft clunk
    Aug 2011
    Gahanna, Ohio
    Quote Originally Posted by coolone View Post
    Were replying to me with an Audi? or are you talking to the OP about the imbedded video (I can't see youtube at work).
  9. #9 Re: New half shaft clunk
    Sep 2014
    ChiTown
    Quote Originally Posted by buck531 View Post
    I actually replaced the wheel bearing with Delco unit before the axle went bad. Nut torqued to 118 ft/lb. Inspected the trans mount after work yesterday, looks squashed so I'll replace that first since it's the cheapest/easiest thing to do at this point.
    2002 Regal GS
  10. #10 Re: New half shaft clunk
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    Just an FYI Napa gets their axles from Cardone. Same box and packaging with a different sticker on the box. I ordered a set of new half-shafts from RockAuto (Cardone brand) and Napa at the same time and they were identical. (Minus the huge price difference!)
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  11. #11 Re: New half shaft clunk
    Sep 2014
    ChiTown
    Trans mount replaced, clunk didn't go away.
    I have a feeling my torque wrench might be "little" inaccurate. I tightened the axle nut some more and clunk went away. Ordered new wrench, will have to compare the two. Anyways...no more annoying sounds.
    2002 Regal GS
  1. Half Shaft Play?
    By 94GrandPrixSE in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-12-2014, 09:07 AM
  2. 06 grand prix gxp cv half shaft
    By DirtDog in forum 5.3L V8 (LS4)
    Last Post: 11-16-2012, 07:39 AM
  3. 06 pontiac GXP CV Half Shaft Replacement
    By DirtDog in forum General Tech Discussion
    Last Post: 09-11-2012, 12:12 PM
  4. half shaft / tranny question - looking at a car to buy
    By EternalX in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-14-2012, 07:30 AM
  5. half shaft cause abs/tcs light?
    By LAIDBACKLUKE in forum Brakes/Suspension/Chassis
    Last Post: 01-29-2010, 08:17 AM
