Thread: Small coolant leak turned into a large coolant leak
Results 1 to 6 of 6
  1. #1 Small coolant leak turned into a large coolant leak
    Jan 2012
    Austin,tx
    So that large leak happen when I was driving and seized up the water pump. Got a new pump in and took out both elbows to take a look at the O-rings(installed aluminum elbows two years ago) they looked bad, but coolant wasn't coming from them but I went ahead and replaced them. As I'm pouring coolant in I got the engine running and everything is smooth but I see coolant dripping from under the car then it stops. It looks like it could be coming from the back passenger side its hard to tell. Then later with the engine off I went to top it off and coolant is coming out as fast as I'm pouring it in at the same spot. I'm not sure what to do at this point.
    06 Grand Prix GT stock, 02 Mustang GT far from stock
  2. #2 Re: Small coolant leak turned into a large coolant leak
    It's kind of hard to guess at where the leak is but the timing cover gasket and a rear freeze plug come to mind of places to leak.
    You'll have to get under it and pinpoint the leak somehow.
  3. #3 Re: Small coolant leak turned into a large coolant leak
    Jan 2012
    Austin,tx
    Yeah i'm not looking forward to it but I'll get back in there and see what I can find.
  4. #4 Re: Small coolant leak turned into a large coolant leak
    Jan 2012
    Austin,tx
    Has a blown head gasket
  5. #5 Re: Small coolant leak turned into a large coolant leak
    A pretty rare failure but can happen.
    Easy enough fix on the engine like these, rear head can be a struggle to take off because they are heavy.
  6. #6 Re: Small coolant leak turned into a large coolant leak
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by DreamerGT View Post
    Where are you pouring the coolant into the radiator or the overflow bottle?
  1. large coolant leak???
    By jakedidi in forum General Grand Prix Discussion
    Last Post: 07-31-2016, 07:09 PM
  2. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  3. Small coolant leak. Radiator drain plug
    By eric37428 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-23-2013, 07:42 PM
  4. Small Coolant Leak - Any Ideas?
    By Hippo Machine in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-23-2011, 08:54 AM
  5. Broken Thermostate Bolt & small coolant leak ?!?!?
    By FlaminWhite97GTP in forum General Tech Discussion
    Last Post: 02-15-2010, 07:32 PM
