Thread: 04 Grand Prix Catalytic Converter Replacement Help
Results 1 to 5 of 5
  1. #1 04 Grand Prix Catalytic Converter Replacement Help
    Jun 2016
    Oregon
    Hello,
    I'm wondering if I'm completely missing something, but I'm replacing the catalytic converter on my 04 Grand Prix GTP and need help. It's an Eastern, nothing crazy, direct fit.
    I can't for the life of me figure out how to remove the front bolts, where it connects to the exhaust manifold. I was able to loosen the right bolt, but I fought with the left bolt for 2 hours. Other than it being a super tight fit and needing to reach it basically from laying on the engine, I've tried various tools with extenders, etc., but nothing would grip the bolt.
    Does anyone have experience with this specifically on an 04 GTP?
    Thanks
  2. #2 Re: 04 Grand Prix Catalytic Converter Replacement Help
    Long extension from under the car with a impact always worked for me or a breaker bar.
    It helps to heat the bolt up with a torch, they come out alot easier.
  3. #3 Re: 04 Grand Prix Catalytic Converter Replacement Help
    Jun 2016
    Oregon
    Thanks! I tried from under the car but couldn't get a good angle on it. I was able to get the right one loosened from the top of the car, reaching behind the engine. I guess that's the main problem, was just trying to get a socket, wrench, etc., to fit on the bolt. Do you remember what tool combination you used with the impact?
  4. #4 Re: 04 Grand Prix Catalytic Converter Replacement Help
    mine stripped out, i used a wrench on the top side and a ratchet with a long extension on the bottom. one side came out, the other side came loose but froze and stripped out, so the angle grinder came into play and i cut the bolt head off. it was rather tight with a 4 inch cut off disk, so if you got a smaller one it would be bast if it comes to cutting em off.
  5. #5 Re: 04 Grand Prix Catalytic Converter Replacement Help
    Jun 2016
    Oregon
    Oh man, that's what I'm hoping to avoid (cutting the bolt off)! I think I may try an impact wrench with an extender and a universal swivel socket, from underneath the car. The bolts angle down toward the ground, which makes it near impossible to get leverage through the engine bay.
  1. catalytic converter replacement
    By Scott MI in forum General Tech Discussion
    Last Post: 04-14-2015, 06:38 PM
  2. I Need Help!!! 06 Grand Prix 3.8 V6 Catalytic Converter
    By TheDoctor15 in forum General Tech Discussion
    Last Post: 01-12-2013, 12:27 PM
  3. 02 Grand Prix quick catalytic converter Question?
    By cmccarty22 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2012, 02:17 PM
  4. Catalytic Converter Removal 99 Grand Prix GT Coupe *HELP*
    By blortz in forum General Tech Discussion
    Last Post: 12-10-2010, 02:05 AM
  5. 2001 pontiac grand prix catalytic converter
    By Reeddawgy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2008, 07:13 PM
