Thread: 05 comp g & 04 comp g wont start....wtf
Results 1 to 4 of 4
  1. #1 05 comp g & 04 comp g wont start....wtf
    Mar 2016
    Florence,MS
    I have a 04 comp g that I drive and a 05 comp g that I'm letting my girlfriend drive. First the 05...My girlfriend was putting new plug wires on and started the car. I heard it back fire and ran out and shut it off. I noticed she mixed up cyl 3 & 5. I plugged them into the right cyls and tried starting it turned over but didn't start. I turned the key off to it out. Waited a minute or two and tried to start again. This time nothing but a click happened as if the battery were dead. I checked with a meter and I get 12v both when the key is on and turned to start. It's got a new alternator and starter about 2 months ago. When I turn the key on every service traction, stabilization and abs message comes on in the DIC. Including reduced engine power. I might be missing one or two but you get the point. I don't have a way to get it to a shop and I don't want to just up and buy a new pcm, bcm, etc and just guess. Does anyone have any experience with this sort of issue? ****ty thing is, a day before she did that, my 04 comp g did about the same thing minus the plug wire screw up/back fire. All the service lights in the dic come on when I turn the key on and the single click when I turn the key to on happens and I have an optima red battery in both cars reading 12v when key is on and turned to start. Besides kicking my girlfriend out of my house, I would highly appreciate any help, suggestions or advice.
  2. #2 Re: 05 comp g & 04 comp g wont start....wtf
    Check any other grounds and all IGN fuses in the fuse block.
  3. #3 Re: 05 comp g & 04 comp g wont start....wtf
    Mar 2016
    Florence,MS
    Naw man. It's kinda weird. I was testing 12v everywhere with my multimeter yesterday and when I got back to the fuel pump I unplugged the harness to make sure nothing was created frayed etc. I plugged them back in and when I put the positive side into the power wire **** just started clicking and it started right up. Fuel gauge doesn't work anymore so I need to figure that out next. But it's running good again
  4. #4 Re: 05 comp g & 04 comp g wont start....wtf
    Mar 2016
    Florence,MS
    That's for the 04 ....05 is due up today. Gonna repeat the same process and change maf to lq4 on it
  1. Topped swapped 06 GP now wont start and scan tool wont comm with ECM
    By jbrltoliver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-31-2013, 08:36 AM
  2. 2004 GTP Comp G -- wont turn left -- intermittent
    By mckillin in forum Brakes/Suspension/Chassis
    Last Post: 07-17-2012, 05:57 AM
  3. Comp G trans in a non Comp G
    By Explicit_Spade in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2011, 10:31 PM
  4. 04 gtp comp g where to start with modding??
    By justin98 in forum General Tech Discussion
    Last Post: 03-21-2009, 11:50 PM
  5. 05 GTP Comp G OEM Remote Start Range
    By Jester331gt in forum General Tech Discussion
    Last Post: 01-04-2009, 08:54 PM
