I took my car in to get some other work done(hub assembly, tire rod, a/c blower motor) and told them about my ABS light coming on. Normally when that would happen in the past, a speed sensor would be the issue and the 'service engine soon' light would come on. However it never did for some reason even though thats one of the problems that came back from the codes the shop found. I did notice after a while, that the antilock brake light would come on when i first started the car instead of driving it a bit (which would then trigger the sensor code - abs pulls when you brake, you can hear the motor on the module, then finally the abs light and trac off light comes on). - I guess this explains the pump gone bad.
I was quoted in the neighborhood of $1,000 for the replacement of the ABS Pump. Should i assume that that price includes just the pump and not a whole new ABS module?
2000 Pontiac Grad Prix
Miles: 252,800
