brettstoner
So you have a poor electrical connection somewhere, electrical component near the point of failure, or intermittent electrical short/open. First clue is everything works fine then the radio cuts out. The radio communicates on the Canbus so we don't know if the problem is being caused by the radio or the radio is on the receiving end of the problem. (The Canbus is the cars network where all the modules talk on, ie BCM, PCM, radio, SDM, TAC, DIC, IPC, HVAC, etc, OBD2 port).
Did the dealer do diagnostic work besides load testing the battery, measuring volt and amp output of the alternator, and cranking the car over attempting to duplicate the condition? Did they read live data to troubleshoot all the Powertrain codes? Did they attempt to pull any body, brake, or network codes? Did they check for battery voltage at the PCM and BCM? Did they measure the resistance of the grounds at the PCM and BCM?
You have lots of diagnostic work to do here. I would not throw parts at it but start checking everything. Start with the basics. We have a known good battery (fully charged) with clean corrosion free connections on all points of the battery cables. All fuses and relays are receiving 12v+ and operational. Hook up a scan tool and read live data. Can you read all sensor data and it makes sense? (Troubleshooting some of those powertrain codes, ie poor connection to PCM, PCM getting funky data from a bad sensor, PCM not getting 12+v or high resistance ground).
Your car is showing multiple problems....
1. Crank but no start. (Are fuel injectors getting 12+, is fuel pump priming, are fuel injectors getting grounded aka commanded to squirt fuel by the PCM, do you have spark while cranking)
2. Radio cuts out. (Check for 12+v on orange wire (B1 connector) hot at all times and purple wire (B3) ignition switched, good ground, is it getting or sending bad signals on the serial data line)
3. All the powertrain codes. (Are you getting good data from each sensor, troubleshoot each p code, are they related, all appeared at same time or developed over time but not addressed, poor ECM connection, etc)
You could have something as simple as a bad connection somewhere, a component reaching the point of failure, poor grounds or low voltage, or a bad component on the serial line sending bad data (I have seen a bad radio cause a no start condition but not common).
If you don't have the tools and experience to troubleshoot electrical problems I would call around to find an experienced diagnostic technician. It's easy to swap car parts. It's hard to troubleshoot intermittent electrical faults. They are worth the price.
