Thread: 02 Grand Prix exhaust help
Results 1 to 10 of 10
  1. #1 02 Grand Prix exhaust help
    Aug 2012
    Doylestown,PA
    I have a 02 Grand Prix I need to know what the part is called in the exhaust that is right past the Cat. It has a bend in it for the 02 sensor. The last shop replaced the Cat and did the Spark Plug defouler trick. The Spark Plug deflouler has ruster away. It has broke off inside this piece I think it will be cheaper to replace it.
    Thanks
    Chris
  2. #2 Re: 02 Grand Prix exhaust help
    Jul 2010
    Coquitlam,BC,Canada
    U-bend.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: 02 Grand Prix exhaust help
    Aug 2012
    Doylestown,PA
    Would you know a place I can buy this?
  4. #4 Re: 02 Grand Prix exhaust help
    Jul 2010
    Coquitlam,BC,Canada
    The u-bend is part of the converter assembly. Why not just remove the defouler and install an O2 sensor?
    Or get a u-bend delete.... http://zzperformance.com/3800/exhaust/ubend-delete.html
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: 02 Grand Prix exhaust help
    you mean the foulers rotted out, ot the bung rotted off the pipe?
    how to make foulers works.
    those two parts are like 5 bucks at the parts store. you drill one out like shown.
  6. #6 Re: 02 Grand Prix exhaust help
    These are the options for replacing that.
    Factory replacement downpipe with cat. Easiest option as long as the cat back bolts aren't rusted. http://www.amazon.com/Walker-54627-U.../dp/B001AGPEA4
    Ubend delete kit from zzperformance. Cheapest option but will need to be welded in http://zzperformance.com/3800/exhaust/ubend-delete.html
    Downpipe from zzperformace. The better option of these three, bolts in place of the factory downpipe, should be an easy swap as long as your catback bolts aren't rusted. http://zzperformance.com/3800/exhaust/zzp-downpipe.html
    If you ever plan on modding your car I would highly suggest a set of headers, most headers on the market come with a downpipe that replaces that section.
  7. #7 Re: 02 Grand Prix exhaust help
    Aug 2012
    Doylestown,PA
    Yes was getting PO 137 went to replace the 02 sensor and the fouler rusted away and part of it is stuck in the O2 sensor port. If I take it to an muffler shop can they cut the bend out and replace it?
  8. #8 Re: 02 Grand Prix exhaust help
    if you still have the U bend int he dp right before the flange to the cat back, have that cut out and new round pipe with a bung for the o2 installed for sure.
  9. #9 Re: 02 Grand Prix exhaust help
    Aug 2012
    Doylestown,PA
    Thanks going today to get it fix and hope to get it inspected too.
  10. #10 Re: 02 Grand Prix exhaust help
    Aug 2012
    Doylestown,PA
    Got it fixed today. Cost me $135.00 had to get resanator replaced and two other pieces cut out and welded in. Car sound so much better. Plus the PO 137 code went away!!
    Thanks for all of your help
  1. Best exhaust for a grand prix gt
    By Kcgp in forum Introductions/Noob Questions
    Last Post: 02-20-2013, 07:27 PM
  2. Exhaust - 04 grand prix gt
    By gordster1122 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2012, 03:18 PM
  3. Grand Prix GXP exhaust on a standard Grand Prix
    By JenniGP in forum General Tech Discussion
    Last Post: 03-29-2011, 10:15 PM
  4. Exhaust for my '05 Grand Prix
    By extreme in forum 04+ Specifics
    Last Post: 03-08-2010, 10:58 AM
  5. Grand prix gt exhaust
    By bballa0740 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-30-2009, 04:55 PM
