Thread: 02 Grand Prix no low beams
Results 1 to 9 of 9
  1. #1 02 Grand Prix no low beams
    Feb 2016
    Cecil, PA
    Ok guys, 2002 Grand Prix gt. The DRL's work but I have no low beam headlights. Place a glove over the DRL sensor and the side Amber lights illuminate but no low beams? High beams work when selected and fog lamps work as well. I cleaned all grounds, replaced the ignition switch and checked all fuses. Not sure if it's related but my door chime sounds when the door is open without a key in the ignition. I've searched the forums for an answer and tried all suggestions related to my issue. Could it be my headlight switch?
  2. #2 Re: 02 Grand Prix no low beams
    SWPA
    HDM relay.
  3. #3 Re: 02 Grand Prix no low beams
    Feb 2016
    Cecil, PA
    I've checked the underhood fuse box and there are no hdm relays only a 60 amp "large fuse" for the headlamps. Is there an hdm relay in one of the interior fuse boxes?
  4. #4 Re: 02 Grand Prix no low beams
    HDM relay is a 2004-2008 issue.
  5. #5 Re: 02 Grand Prix no low beams
    SWPA
    Yeah, wasn't thinking clearly on that one since I just had an issue with mine on my car.
  6. #6 Re: 02 Grand Prix no low beams
    Jul 2010
    Coquitlam,BC,Canada
    Do they work with the headlight switch?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: 02 Grand Prix no low beams
    Feb 2016
    Cecil, PA
    The low beams do not come on with the switch either. If i turn the switch to parking, parking lights come on, when i turn to headlights no change. But the higbeams will work when activated by the stalk at the steering column.
  8. #8 Re: 02 Grand Prix no low beams
    Jul 2010
    Coquitlam,BC,Canada
    Time to get out the multi-meter (or test light) and a wiring schematic. I'd start with the bulbs; do they work. Check the headlight switch; is it getting power.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: 02 Grand Prix no low beams
    Feb 2016
    Cecil, PA
    Just an update. While tracing wiring with a multimeter, the problem was loose connections at the high beam stalk. All functions are working now. Thank you to those you took the time to help and comment on the post.
  1. 05 gtp lows beams stay on with high beams.
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 06-15-2014, 01:24 PM
  2. Hi beams and low beams at the same time?
    By PurpleGuy in forum Audio, Security & Visual Electronics
    Last Post: 06-06-2012, 12:38 AM
  3. No Low Beams, Please Help
    By Andrew Nelson in forum General Tech Discussion
    Last Post: 06-01-2012, 05:41 AM
  4. 2006 Grand prix low beams shut off randomly
    By blowntbss in forum General Tech Discussion
    Last Post: 08-08-2011, 04:58 PM
  5. Please help me 2006 Grand prix low beams dont work
    By singlemom in forum General Tech Discussion
    Last Post: 06-07-2010, 10:02 PM
