Thread: Heater blowing hot air but not switching from defrost to floor when selected
Results 1 to 5 of 5
  1. #1 Heater blowing hot air but not switching from defrost to floor when selected
    Feb 2016
    I have a 2004 Widetrack. The heater is blowing hot air like it should, but when the selector knob is moved from defrost to floor or any other selection it will only stay blowing air on defrost. What should I be looking for starting with simple first? Thanks
  2. #2 Re: Heater blowing hot air but not switching from defrost to floor when selected
    Maybe a possible blend door issue, like it's not switching.
  3. #3 Re: Heater blowing hot air but not switching from defrost to floor when selected
    Sep 2014
    Worcester, MA
    The blend door actuator is the first thing I'd be looking at.
    -BC
  4. #4 Re: Heater blowing hot air but not switching from defrost to floor when selected
    silly rabbits, blend door actuators control hot and cold or the mix of air. only...why its called a blend door actuator.....
    your flow direction is vacuum powered from the engine. line runs off the intake manifold to the firewall down the fender under the fuse box, look for it to be busted. battery change can snap the line easy.
    cant find a busted line under the hood, your off to climate control or the vacuum box in the console near the firewall.
    or rarely, the plastic linkage in the dash breaks all by its self.
  5. #5 Re: Heater blowing hot air but not switching from defrost to floor when selected
    Feb 2016
    The blend door actuator is functioning. Where exactly are the vacuum lines located? I can't seem to find any. Also the climate control or vacuum box, where are they located on the firewall? Thanks
  1. A/C/Heat air blows ONLY from defrost vents and floor
    By Ridin ON Chrome in forum General Tech Discussion
    Last Post: 07-27-2015, 09:47 AM
  2. a/c not working and heat not switching to floor help!!!!!!!!!!!!!!!!!!!!!!!!!!
    By Brett Muszynski in forum General Tech Discussion
    Last Post: 04-15-2012, 02:29 AM
  3. need help a/c not working and heat not switching to floor
    By Brett Muszynski in forum General Grand Prix Discussion
    Last Post: 04-15-2012, 12:20 AM
  4. 98 gtp w/ DCC will blow on defrost or vents but not floor-please help
    By Liquifire in forum General Tech Discussion
    Last Post: 08-03-2011, 06:07 PM
  5. heater not blowing hot air
    By mfowler12 in forum General Tech Discussion
    Last Post: 12-09-2010, 11:19 PM
