Thread: P0140- Bad Cat or Sensor?
Results 1 to 13 of 13
  1. #1 P0140- Bad Cat or Sensor?
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    SEL light turned on today and this is the code that it's giving me. The car is a 98 GT with 61K miles one it. There's no serious engine mods and only exhaust work done after the cat. I've done some searching and know this is the code for the rear o2 sensor but what I'm not sure about is the cause. On a car that old with that amount of mileage would you guess it's a worn out sensor or a bad cat? Is there a test I could do that would tell me which one it is? I already have a 2.5" downpipe sitting in the garage and a Reptile tuned PCM that will erase the code so it's not a big deal but I'm just curious. I've been lazy installing those things but looks like I might have to sooner rather than later now. Just have to order a emulator now.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  2. #2 Re: P0140- Bad Cat or Sensor?
    http://www.obd-codes.com/p0140
    not a cat, the o2 heater is dead.
  3. #3 Re: P0140- Bad Cat or Sensor?
    Buffalo, NY
    Alright so I guess through everything I read I misunderstood what it meant a little bit. Does that mean though that replacing the sensor will solve the problem?
  4. #4 Re: P0140- Bad Cat or Sensor?
    it should. hard part is getting the old one out. they like to rust in there and fight on the way out.
  5. #5 Re: P0140- Bad Cat or Sensor?
    Buffalo, NY
    Thanks Scotty. Looks like i'm going to get an emulator and just swap it with the DP this spring/summer
  6. #6 Re: P0140- Bad Cat or Sensor?
    you can just delete it and tune it out. mines long gone.
  7. #7 Re: P0140- Bad Cat or Sensor?
    Buffalo, NY
    I actually have a PCM from Reptile with the code tuned out. I'm going to get the simulator just to be safe though being in NY with the state inspections.
  8. #8 Re: P0140- Bad Cat or Sensor?
    run the pcm and forget about the rear o2. it will show ready and thats all that matters for inspection.
    pretty sure i got 24 codes deleted or so. i passed inspection.
  9. #9 Re: P0140- Bad Cat or Sensor?
    Buffalo, NY
    Alright guess that's what I'll do then. Should I just swap the bad one over then when I switch dp's?
  10. #10 Re: P0140- Bad Cat or Sensor?
    good chance it wont come out at all. not with out a torch maybe. you can have no o2 at all with it tuned out. or put a wide band o2 sensor in the hole.
    if you stop by a local garage they have o2 sensor plugs laying around sometimes. they come in new dp's and they tend to save em time to time. one of my local guys has a box of em.
  11. #11 Re: P0140- Bad Cat or Sensor?
    Buffalo, NY
    If I put a plug in there could that cause a problem come inspection time if someone notices?
  12. #12 Re: P0140- Bad Cat or Sensor?
    i dont think they count o2 sensors, as long as it shows system "ready" its a go.
  13. #13 Re: P0140- Bad Cat or Sensor?
    Buffalo, NY
    That's what I'll do then
  1. P0140
    By alivepills in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-08-2010, 05:07 PM
  2. P0140 code and boost gauge acting weird
    By 99prixgt in forum General Tech Discussion
    Last Post: 10-14-2009, 07:50 AM
  3. Service Engine Soon P0140 P0118 P0113
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-02-2009, 08:12 PM
  4. Service Engine Soon P0140 P0118 P0113
    By spenc938 in forum General Tech Discussion
    Last Post: 03-27-2009, 12:34 AM
