My rear window defrost has quit working. Ive checked the fuse in the glove box and I can hear the relay click on when I push the defrost button. Any other ideas on how to fix ?
I would check the tabs as well. Seems obvious, but sometimes one seems to hang just above the defroster grid without touching.
Thanks ill check it all out
Look at the coil in the window and see if there are breaks. Sometimes you can't see them though
Sent from my SM-N900T using Tapatalk
I checked the wires and tabs at the back window they look good. I'm gonna try and check voltage and see where its at, I assume I should get 12v back there with the rear defrost on ?
