Where do i get the software and how do i register. I googled for software but it seems most of the forums that had it are shut down
Sent from my LG-D851 using Tapatalk
Hmm ok. Also ive been reading the user manual and it talks about how you can only use it on the model year and make you bought it for. Whats up with that?
Great! Status update ive been driving with the a/c on because i dont get misfires when its on and my ltft is still out of wack while driving its always in the positive never once goes in the negative it usualy stays in 0 to +7 range
I did spray everything with carb cleaner and i didnt get any changes in rpm the only thing i can think of is if theres a leak in the lim gasket. Would a leaky valve cause loss of vaccum?
The vaccum isnt stable at idle usually bouncing 20-18 but when im actually driving and coasting to a light not on throttle it bounces between 20 and 16
So ill be doing a dry compression test in the morning. If that cylinder is bad i heard you can do a wet compression test. What kind of oil and how much oil do you put through the plug holes for the wet test?
Smh you act like we are there in front of your car who knows what ya did.....
Sent from my SM-G920V using Tapatalk
The fu*kk?? This is why when you don't know what your doing chances are you shouldn't do it this thread is so shot lol
So i went to my dads house today and got the compression tester. Then i went down to the exaust shop and they didnt find any leaks with the headers and then i found a place that sells 100 octane so i put a few gallons of that in to achieve closer to a 93 rating and now im only at 1 degree or less of kr at wot. Amazing that a little bit of high octane can do that much.
I have the tester but havent run the test yet. It hasnt misfired for two days. It was 9$ a gallon for 100 octane... Although they had 110 for 9$ as well but i think it was leaded
Hey scotty what kind of operating system works with the dhp. I was looking for an xp but now a days its hard to find one that old. Does vista or 7 work?
