till they look smooth. your only doing light pressure, its not like you can grind em to nothing, unless the pitting is that deep.
even the valve seats were pitted up some.
before.
after
before.
after
Also im buying all my bolts and gaskets right now do i need a new crankbolt? I didnt think so but noticed zzp had it in there top swap gasket kit
Sent from my LG-D851 using Tapatalk
Ok so im getting my heads put back together minus the 1.9 rockers im still trying to find. I got felpro valve seals and im confused if im supposed to take the metal rings off to install them or just force it on?
yup, just push em on. if you got felpros mine came with a plastic condom to cover the locks so the seal slides past them smoothly and dont tear the seal up.
you can also use like a 10 mm deep socket to push them all the way down.
