Thread: Some more top swap questions! Yay!
Page 14 of 71 FirstFirst ... 412131415162464 ... LastLast
Results 261 to 280 of 1411
  1. #261 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    How do i know which ones i will need them with? If i find zzp modified rockers those woikdnt need new ones right?
    Sent from my LG-D851 using Tapatalk
  2. #262 Re: Some more top swap questions! Yay!
    that i dont know. mine came with them, i used them.
  3. #263 Re: Some more top swap questions! Yay!
    Oct 2015
    Hmmm ok well ill do some research then, maybe email zzp. Thanks scotty!
    Is there any benefit of getting different pushrods besides the ones you need for your set up? Like are some lighter or flow better?
  4. #264 Re: Some more top swap questions! Yay!
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    ZZP modified rockers are modified stock rockers so you do not need to replace pushrods. Yella Terra requires a longer pushrod. Sometimes you may need a stronger or shorter length pushrod depending on setup, heads decked, etc. Not a performance gain item so much as just the correct length/strength.
    Biggest benefit is cam or rockers. Then replace springs with right retainers to match cam. For high rpm titanium locks, retainers, etc reduce weight to gain a few rpm before float. Pushrods are correct length and strength. And timing chain may need to be upgraded (along with other mods to fit double roller) if additional strength is needed based on aggressiveness of cam.
    For your discussions I would recommend the YT rockers and pushrods from Intense or ZZP modified rockers. Replace springs, stem seals, and retainers. Consider replacing timing chain, dampener, and / or gear set. Ensure heads and valves are good and run it. Maybe a little head work if you want to spend $.
    Next step up would be keep the stock rockers and run a mild cam. My recommendation personally.
    Don't forget in all of this to get supporting mods including intake, exhaust, and tuning. Bolt on top swap seems to get a little expensive! Haha
  5. #265 Re: Some more top swap questions! Yay!
    GT Level Member andesmint's Avatar
    Jun 2012
    Minot, Nd
    adding to what brettstoner said here. seriously don't over look your supporting mods. on my first topswap build i had ZZP stainless headers, a 3" TOG DP with a 200 cell cat and an intake. that probably would have worked fine but it needed finer tuning and in the end i chipped a piston. on this build i installed a S1x cam and Ls7 lifters, also 90# springs and im still crossing my fingers
    2000 GT Mods: HAI, 10.5mm wires, rebuilt 60k motor, ZZP stainless headers, magnaflow mufflers, fresh paint job,L-67 top swap, Ported SC...
  6. #266 Re: Some more top swap questions! Yay!
    Oct 2015
    So i finally got a valve spring remover today so i took out all the old valves and cleaned up the insides and did notice a crack in between the exaust and intake valve openings on one cylinder. I have gotten mixed information some people say its not a big deal others say differently so which one is it?
  7. #267 Re: Some more top swap questions! Yay!
    Donating Users timboku's Avatar
    Montgomery, IL
    Quote Originally Posted by suitercrew View Post
    90percent of 3.8s have that crack..it's fine.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  8. #268 Re: Some more top swap questions! Yay!
    Jul 2014
    Toledo, OH
    90% of our heads probably have the valve to valve crack. It took me several sets of heads to find good ones. Will the crack spread or open up into the water jacket..... Who knows. Maybe have your local shop check them. Maybe you can run them another 100k and be fine.
    I personally did not feel comfortable with cracks worried they may open up into the water jacket or cause a hot spot on the edge and get preignition. Running boost I wanted to be more conservative personally but there are many stories of guys on here running cracked heads without problems. I would evaluate how big and deep the crack is. What is your tolerance to risk, reliability, how much boost, and how long will you have the car. Many people run cracked heads and are fine.
  9. #269 Re: Some more top swap questions! Yay!
    Oct 2015
    Do i need a new valve theres these scratches on it multiple this is the furthest one down the stem.
  10. #270 Re: Some more top swap questions! Yay!
    thats fine. just make sure its smooth and not burred.
  11. #271 Re: Some more top swap questions! Yay!
    Polish it out or just run it.
    Little marks like that don't matter.
  12. #272 Re: Some more top swap questions! Yay!
    Oct 2015
    Well when i slid it out of the valve guide it definately didnt come out like the other valves. A little extra gentle pulling was required
  13. #273 Re: Some more top swap questions! Yay!
    Use a wire wheel on a bench grinder and it will smooth everything out.
  14. #274 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok thanks guys i was gonna go to my dads and use his wire wheel grinder to clean the valves anyway so that works out.
  15. #275 Re: Some more top swap questions! Yay!
    Jul 2014
    Toledo, OH
    How do the exhaust valves and seats look? When I was pulling heads most of the exhaust valves and seats were pretty pitted and I ended up doing a valve job to get good sealing.
  16. #276 Re: Some more top swap questions! Yay!
    Oct 2015
    Ill take a look when i go in tge garage but i think all the seats looked fine even where the crack is it still looks flush. I planned on lapping all of them anyway though.
  17. #277 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok so i was just now able to get all the valves cleaned up and the intake ones look good but like you said the exaust valves are pitted
  18. #278 Re: Some more top swap questions! Yay!
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Lap them.
  19. #279 Re: Some more top swap questions! Yay!
    mine were pretty bad but cleaned up pretty nice.
    after lapping some, the exhaust got more time lapping to finish it off.
  20. #280 Re: Some more top swap questions! Yay!
    Oct 2015
    About how long should i lap them for im kinda scared ill grind them down to much haha
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
