Thread: Some more top swap questions! Yay!
Page 52 of 71 FirstFirst ... 242505152535462 ... LastLast
Results 1,021 to 1,040 of 1411
  1. #1021 Re: Some more top swap questions! Yay!
    Donating Users timboku's Avatar
    Montgomery, IL
    At least 30mins.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  2. #1022 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    Any exhaust leak pre cat is going to skew the o2 readings
  3. #1023 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Ok i got the battery unplugged right now. Would i notice an instant imptovement in kr or would it still be terrible until i drive it for a while?
    Sent from my LG-D851 using Tapatalk
  4. #1024 Re: Some more top swap questions! Yay!
    Montgomery, IL
    Again...no WOT runs until your trims are relearn ed by driving without boost, you should notice our trims at idle will be better and drive with smooth accelerations up to say 50 and tried to run that on a flat long road for a little bit..no boost for the first 20 mons at least, look at your trims as your sriving, they should be getting to plus or minus 5...once this is achieved, you can go WOT making sure your trims lock at 0.
  5. #1025 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok when i go on break ill do this
  6. #1026 Re: Some more top swap questions! Yay!
    dont expect the trims to learn fully in 20 minutes, can take a few days of driving.
  7. #1027 Re: Some more top swap questions! Yay!
    Oct 2015
    I just want to know if i fixed it! Lol
  8. #1028 Re: Some more top swap questions! Yay!
    that will make it loud from the engine bay for sure lol and mess up the trims for sure.
    drive it nice for a day or two watch the trims when they settle down at the same number consistently at idle and under normal driving you know they have learned.
    the other way is when you give it over 40% throttle the trims will lock in at 0.0 once learned they likely wont, they will lock in at a + - number.
    now they may look ok, but you turn it off, let it sit a 2 or 3 minutes, then re start it, the trims will be all over again.
    fastest way i can get my crap to learn is 3, 10 mile trips, turning the car off at each 10 mile trip.
  9. #1029 Re: Some more top swap questions! Yay!
    Oct 2015
    How long do you wait before starting it again and going on another "trip" should i do just city driving or city and highway?
  10. #1030 Re: Some more top swap questions! Yay!
    i go 10 miles down the hwy, vary your driving like that other guy said leave it in 3 rd for a while slow down bring it back to speed, back drive, mix it up, then turn it off for like 2 minutes, open the door turn the key on and off a few times too, then re start it, repeat two more times.
    by the time i get back home ive gone 40 miles pretty much. then some times they will change a bit more over the next few days.
    when im tuning ill let things go for a week so i know it learned, i also dont drive much at all. car sits a lot and does short trips when i do drive it.
    i just did some tuning a few days back, crap just learned yesterday got the 3.2 at 15.5 timing wot kr free today. and its pretty warm out today.
  11. #1031 Re: Some more top swap questions! Yay!
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I've been kinda following this, but you haven't had an issue with your fuel lines leaking at the connections using the N/A lines by chance have you?
    2012 F150 STX
    - Gonna be a race truck
  12. #1032 Re: Some more top swap questions! Yay!
    Oct 2015
    Not that i have seen. They seam to be working great
  13. #1033 Re: Some more top swap questions! Yay!
    Apr 2012
    Dayton, OH
    Ahh good, I might being doing a top swap with a Gen V so I'm trying to plan out all the small things I might run into.
    2012 F150 STX
  14. #1034 Re: Some more top swap questions! Yay!
    russ, you need a l67 rail. the l32 wont work on your car.
  15. #1035 Re: Some more top swap questions! Yay!
    Apr 2012
    Dayton, OH
    I got that covered, same with injectors and heads as I sold the l32 heads yesterday.
    2012 F150 STX
  16. #1036 Re: Some more top swap questions! Yay!
    Oct 2015
    I have a code cor cylinder 3 missfire grr
  17. #1037 Re: Some more top swap questions! Yay!
    check the wires not melted on a header tube. #3 is the middle front plug. pull i tout make sure its not smashed........if the plug is smashed thats not good.
    please tell me you were driving normal and it started to misfire,,,,,,,not wot.
  18. #1038 Re: Some more top swap questions! Yay!
    Oct 2015
    Yes driving normal. I just switched the wires between cylinder 3 and 5. Hopefully ill get a code for cylinder 5 now and just go get new plug wires
  19. #1039 Re: Some more top swap questions! Yay!
    Montgomery, IL
    The l32 heads would have worked
  20. #1040 Re: Some more top swap questions! Yay!
    Apr 2012
    Dayton, OH
    Quote Originally Posted by timboku View Post
    I know, this is all part of my weird plan. That should work maybe.
    Sent from my SM-S902L using Tapatalk
    2012 F150 STX
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
