Thread: Some more top swap questions! Yay!
Page 51 of 71 FirstFirst ... 41495051525361 ... LastLast
Results 1,001 to 1,020 of 1411
  1. #1001 Re: Some more top swap questions! Yay!
    on the outside is fine.
    headers are much thinner, the engine sounds louder under the hood with them.
  2. #1002 Re: Some more top swap questions! Yay!
    Donating Users timboku's Avatar
    Montgomery, IL
    Your worried about the leaks before the 02 sensor..so the cat doesn't matter..cross over is biggest issue
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  3. #1003 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Ok well i would assume if i did have a leak it would be in the crossover anyway cause the frickn thing was a huge pain and wouldnt line up right so in the a.m ill make a trip to autozone. Even if it doesnt fix the problem it never hurts to try the cheap fix lol
    Sent from my LG-D851 using Tapatalk
  4. #1004 Re: Some more top swap questions! Yay!
    Montgomery, IL
    I got 20bucks, you rtv that cross over and she gets dialed in ...had same issue....also make sure the bolt that holds the egr tube to the header is tight as well and or rtv that connection as well.
  5. #1005 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    That's what happens when you buy cheap headers lol it never hurts to re-check the manifold bolts either.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  6. #1006 Re: Some more top swap questions! Yay!
    Oct 2015
    That would be soooo great!!
  7. #1007 Re: Some more top swap questions! Yay!
    Oct 2015
    Hey im on a budget! Haha but all things considered i think the sd headers were pretty decent quality. They deffinately needed some tweaking to come together but for a third of the cost of other headers id say its worth the pain.
  8. #1008 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    You can always just start the car up and cup your hand around the crossover joint and feel for air it's not really hard to tell if it's leaking
  9. #1009 Re: Some more top swap questions! Yay!
    Oct 2015
    How big would the leak have to be to throw fuel trims off?
  10. #1010 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    I feel like if it was that big you'd hear it it'll sound like a pos ticking time bomb lol
  11. #1011 Re: Some more top swap questions! Yay!
    Montgomery, IL
    Quote Originally Posted by suitercrew View Post
    Pin hole...
  12. #1012 Re: Some more top swap questions! Yay!
    Montgomery, IL
    And SD headers are best bang for buck..rtv and band clamps and they are fine for a budget build
  13. #1013 Re: Some more top swap questions! Yay!
    Oct 2015
    See and thats what my dad said but im just not experienced with how it should sound but like i posted earlier i noticed a decently loud ticking on my drive home and it was clearly from the exaust and i have magnaflow mufflers that sound totally different now then they did before the swap but i just figured that was because of the headers and such
  14. #1014 Re: Some more top swap questions! Yay!
    Montgomery, IL
    Any unmetered air that enders the system throws trims off...most common are vac. Leaks and exhaust header leaks.
  15. #1015 Re: Some more top swap questions! Yay!
    Oct 2015
    One last question with the copper rtv can i put it on and then go drive with it or how long does it need to cure before i drive
  16. #1016 Re: Some more top swap questions! Yay!
    Montgomery, IL
    I'd wait a good 5 to 8 hours..
  17. #1017 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok cool ill probably do it in my works parking lot and by the time im off itll be good to goooo! Hopefully.. Thanks for the great advice! I gotta get some rest, i will update tomorow and let everyone know how it works out!
  18. #1018 Re: Some more top swap questions! Yay!
    Montgomery, IL
    Make sure you disconnect battery for a good hour to reset the fuel trims, and no WOT runs until after a good 20 to 30 min of steady acceleration and cruising...watch your trims see if they are closer to 0.
  19. #1019 Re: Some more top swap questions! Yay!
    the only time i used rtv was when i clamped my cat in temporary to get through inspection. i waited no time, fired it up and it was sealed.
    it either seals it, or it dont in my book.
    copper rtv is best for the exhaust
  20. #1020 Re: Some more top swap questions! Yay!
    Oct 2015
    So how long do you leave battery unhooked? Also no one laugh but i didnt feel any leaks coming from the crossmember so i jacked the car up got under it and i forgot to tighten the clamp that goes from the header to the downpipe. Which normally wouldnt be a big deal but since i moved the o2 sensor to the ubend it apparently is...
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
