Thread: Some more top swap questions! Yay!
Page 5 of 71 FirstFirst ... 345671555 ... LastLast
Results 81 to 100 of 1411
  1. #81 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    Quote Originally Posted by suitercrew View Post
    Ok so you have 2 bottles though right?
    Sent from my LG-D851 using Tapatalk
    yes, are you looking for L67 injectors?
  2. #82 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Yup
  3. #83 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    What are you willing to pay? I have a set of flow matched L67 injectors from zzp that have like 5,000 miles on them I might upgrade to 42lb.
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  4. #84 Re: Some more top swap questions! Yay!
    Oct 2015
    Well i have no idea what a good price is or what flowmatched even means
  5. #85 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Well I paid 150 plus shipping flow matched means they put them on a machine and basically pick out sets of 6 that flow the same so each cylinder is getting the exact same about of fuel.
  6. #86 Re: Some more top swap questions! Yay!
    Oct 2015
    Hmm well dang id hate to pay more for injectors then i did for my whole m90 haha. Ill probably pass unless you start feeling pretty generous!
  7. #87 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Haha okay.
  8. #88 Re: Some more top swap questions! Yay!
    Oct 2015
    So when i redo my heads i was thinking of putting in stiffer springs because ill probably pick up some 1.9 rockers later down the road. I dont know much about valve train though so would there be any downside or upside to installing stiffer springs on stock rockers could i tune my shift points higher or something??
  9. #89 Re: Some more top swap questions! Yay!
    Oct 2015
    Also do i need an l67 map sensor or how does that work?
  10. #90 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    you need an L67 map sensor and a wire harness conversion to be able to plug it in. I have an extra map sensor that I would let go for 20 bucks, and you can have the bracket that bolts it to the supercharger, but shipping is going to be more because the bracket is bigger than it needs to be. Map stands for manifold absolute pressure. the way a supercharger or turbo works is that it increases the pressure in the manifold, so the atmosphere gets sucked in more to fill the void created by the increased pressure, and a 1 bar map sensor doesn't have the capacity to measure the increased manifold pressure, while an L67 does because it is 2 bars. you can get the wire harness conversion from caspers electronics, and maybe someone can chime in if you can just find someone doing a partout and have the map sensor wire harness cut off and spliced/soldered in on your car.
    you should be fine running a heavier valve spring on stock rockers, but I'm not sure I would mess with the shift points until you actually do the rockers. some people suggest the 90lb valve springs, while others suggest 105 lb.
  11. #91 Re: Some more top swap questions! Yay!
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by Tonkin2000GT View Post
    If you buy the zzp supercharger oil they have it so you only have to buy one bottle and pour the whole thing in.
    Don't you just fill it up until it starts coming out?
  12. #92 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    Quote Originally Posted by SubwayBrat View Post
    zzp sells the small 4 ounce bottles, so you end up needing 2
  13. #93 Re: Some more top swap questions! Yay!
    Oct 2015
    Quote Originally Posted by SgtMarshal View Post
    Ya i was reading all the top swap forum and i didnt see any mention of needing a map sensor but i was looking at the vaccum diagram for the sc and was trying to figure out how that would work. I thought the map was clipped on to the fuel rail? I also have the sc bypass actuatorbut not the bypass solenoid, but i heard you dont need one if you just run a vac line to somewhere there sees only vaccum. Is there any other parts im forgetting?
  14. #94 Re: Some more top swap questions! Yay!
    map and its pig tail is what you need. cut and splice the plug in place of yours.
  15. #95 Re: Some more top swap questions! Yay!
    Oct 2015
    How far down should i cut the wire since it moves locations do i need an extra foot of wire or just a couple inches?
  16. #96 Re: Some more top swap questions! Yay!
    id take as much of the donor pig tail as you can. where you mount it really dont matter, as long as its plugged in and has a vac line to it it works. but you dont want to see it on the front of the engine if you dont have too.
  17. #97 Re: Some more top swap questions! Yay!
    Oct 2015
    Ooo ok that makses sense now. My lim i got yesterday didnt come with the bolts but i heard my l36 bolts are the same and i can use those is that true?
  18. #98 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    a foot is plenty, better to have more than less. you can always trim it again if you want. it doesn't really matter how you have your vacuum lines set up as long as everything gets plugged in.
  19. #99 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    lim bolts should be the same, probably would be a good idea to clean the threads so they go in easier and don't lose their torque.
  20. #100 Re: Some more top swap questions! Yay!
    not sure they are the same bolts. the na bolts look much thinner. get bolts form a junk yard sc.
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
